I need help!!!
Old Mar 19, 2006 | 04:44 AM
ZodtC's Avatar
Default I need help!!!
Okay I just recently replaced my stock front and rear speakers with 6.5 infinity pefrect in front and 5 1/4 in the back. Before i used to play songs with bass and it would sound pretty good with my stock speakers, it would actually bump a little. Now all i have is highs and no bump at all it's weird... are the infinities just highs only and not even a lil bump??? Thx guys, im newb. Also, theyre powered with the infinity amp. Power Output 111 watts RMS x 4 channel at 4 ohms and ≤ 1% THD + N 278 watts RMS x 2 channel at 4 ohms, 14.4V supply and ≤ 1% THD + N
Signal-to-Noise Ratio 81dBA (reference 1 watt into 4 ohms)
Dynamic Power 164 watts at 2 ohms
Old Mar 19, 2006 | 05:05 AM
SNOOP97DAWG's Avatar
you need to run wires and straight to an amp....normally speakers of that nature or any speakers in the front of the car you should only listen to highs and leave the bass to a sub
Old Mar 19, 2006 | 06:59 PM
fujitech43's Avatar
check where you have your crossover set to you might need to adjust it some
Old Mar 19, 2006 | 07:14 PM
honey0bucket's Avatar
when you put aftermarket speakers in your car they are almost always used to hear the hiighs over your sub. simple solution, get a couple 8 inch subs and throw em in the floor of the trunk. you'll be good to go.
Old Mar 19, 2006 | 07:21 PM
speddlysmitt's Avatar
Welcome to the world of Infinity. I had those same speakers in my old car. You will get some extra bass after the speakers break in. Th thing is Infinity tweaters are much louder then the mid bass speakers. You have to run a subwoofer to really even out the sound.
Old Mar 19, 2006 | 09:29 PM
ZodtC's Avatar
i was thinkin that ^^^ ive had em for couple days now. I think i prob will go with a basslink t, would that give me the little bump i want?
Old Mar 19, 2006 | 11:12 PM
Yea the Basslink is pretty nice for the size. I had the clear one in my last car. I was going to use it for this one but some how the thing broke when I had it sitting in my storage room.
Old Mar 20, 2006 | 05:41 AM
Harmonic_tC's Avatar
also make sure they are not out of phase. that would elimnate your lows as well.
Old Mar 20, 2006 | 07:54 AM
reagulator's Avatar
have you tried xA mode?
Old Mar 20, 2006 | 05:45 PM
SCI_TC_GUY's Avatar
check your crossovers on the amp!!!!! the High Pass (HPF) should be set to about 60Hz... maybe 80Hz... no more than that though...
also, most aftermarket speakers are less sensitive because they're more "hefty" and generally don't react as much to power input....
best option here is make sure your amp is set correctly and get a sub..
Old Mar 21, 2006 | 06:58 PM
ZodtC's Avatar
okay thank u all, i dont have stock radio, i got the jvc kd-avx-2
Old Mar 21, 2006 | 06:59 PM
ZodtC's Avatar
Hey harmonic, what does it mean when u say out of phase?
Old Mar 21, 2006 | 07:01 PM
SCI_TC_GUY's Avatar
^^ out of phase means the speakers +and- are backwards
Old Mar 22, 2006 | 02:01 PM
BryanCPA's Avatar
How do you switch to xA mode?
Old Mar 22, 2006 | 02:40 PM
^^^that wont apply to you since you dont have the stock deck
Old Mar 22, 2006 | 08:36 PM
BryanCPA's Avatar
But for those of us who do have the stock deck, how do you switch to xA mode?
Old Mar 23, 2006 | 12:06 AM
RoswellScion's Avatar
Hold down the SSP button until it beeps. Change from left to right using the volume ****.
Old Mar 23, 2006 | 01:04 AM
wc01's Avatar
hey thats pretty cool i never knew i could do that. what is the purpose for that
Old Mar 23, 2006 | 05:19 AM
It is there because the same head unit goes in the xA, xB, and tC. Its versatile and is cheaper for Toyota and the consumer to have a universal head unit.
Old Mar 23, 2006 | 11:40 AM
SCI_TC_GUY's Avatar
each setting has different equalization characteristics to give "optimum" sound for the interior dimentions/speaker placement for each car... I still think they got them all mixed up though...
