dome light wiring - very quick question
Old Apr 6, 2006 | 07:33 PM
midtowndesi's Avatar
Default dome light wiring - very quick question
can i simply wire that by tapping into the stock xB dome light wires? do i need to add a resistor or anything of that nature?
thank you guys in advance!
- sh00k
Old Apr 6, 2006 | 07:38 PM
Tomas's Avatar
Admin Emeritus
If that device is designed to work with 10-15 volts input, you should be able to simply wire it to the existing domelight wiring. If not, you will likely need a series resistance. Can't tell from the pic. Sorry!
Old Apr 6, 2006 | 08:00 PM
Thank you for the info, Tomas! You are always helpful!
I am thinking about buying a few of these (4) and want them to all run off the dome light (ie - they turn on when the doors are opened. How would the connection in a series look? what other parts would i need?
- sh00k
Old Apr 6, 2006 | 08:22 PM
Tomas's Avatar
Admin Emeritus
Assuming they are designed for automotive voltages, and assuming you want them only to respond to doors or hatch opening/closing to turn on/off, you would simply connect the red wire from the new LED light to the blue/yellow wire at the dome light, and the black wire from the new LED light to the red/yellow wire at the dome light.
Here's the schematic:
IF, HOWEVER, the LED lights are made for some other voltage, and not the 'nominal 12VDC' of a vehicle, you will need to add a resistor between the red LED lead and the blue/yellow wire...
Old Apr 6, 2006 | 09:49 PM
Tomas - awesome diagarm! ps - the lights are rated for 9v to 18v dc.
How would it be possible to install 3 of the lights (picture in my 1st post) by attaching it to the wires in the dome light? I am thinking about attaching all 3 to the dome light wires but then running them to different locations - IE - 1 towards the front, 1 towards the middle and 1 towards the back of my xb - all along the roof.
This will be my last Q - i think! lol
- sh00k
Old Apr 6, 2006 | 11:00 PM
Tomas's Avatar
Admin Emeritus
What you describe should work just fine. Each of your 'extra' lights would hook up to the dome light wires in exactly the same way as the first.
If the LEDs are set up internally the way I expect they are, the additional load should be no problem at all to the control circuitry, and the LEDs will turn on and dim just like the original dome light.
horsefeathers
Sep 17, 2023 11:12 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
BLKTOYBOX
10
Mar 2, 2004 08:36 PM
tenten
Nov 24, 2003 04:52 AM
