car problem
Old Apr 14, 2006 | 02:22 AM
fantmtc's Avatar
Default car problem
Hey guys, i just had intake and header installed on my car last monda. ran fine for awhile then started to run not smoothly. called weapon-r for tech support sd to reset ecu. reset ecu didnt run engine hard now have a burning smell coming from engine any suggest or know anybody that could look at car. any info would help.Thanks
Old Apr 14, 2006 | 02:29 AM
RockBlocker's Avatar
Burning smell can be just break in or something got on the header.
Old Apr 14, 2006 | 02:39 AM
fantmtc's Avatar
there was no smell after a couple of days, but since i reset ecu tiday it started to smell again
Old Apr 14, 2006 | 02:56 AM
deofaz's Avatar
i can only think that something is loose and you are loosing exhaust somewhere. Mine ran a little choppy at first, but the ECU had to adjust to the new set up.
Old Apr 14, 2006 | 03:06 AM
fantmtc's Avatar
somebody told me that i should have my headers retightned after couple hundred miles maybe i will do that and see if it does better and wait a couple of days to see if smell goes away.thanks
Old Apr 14, 2006 | 02:08 PM
NoLimitzBuilt's Avatar
Team No Limitz
so are you running the header and S pipe? Cause if I remember right you have to run both of that with there set up. Most likely just something on the header.
Old Apr 14, 2006 | 02:25 PM
Mooneyzs's Avatar
Team No Limitz
Just as everyone else has said the burning smell is just that of the new header and its normal. I will go away in a few days. and Yes you will want to check your bolts and snug them back up because they will loosen up a bit. which is normal after installing headers.
Old Apr 14, 2006 | 03:25 PM
TheBlade's Avatar
could be a blown gasket on the header and your smelling excessive amounts of exhaust. ...I'm thinking the aftermarket gaskets arent as good as factory
Jordly221
Feb 13, 2019 05:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
fluxingnation
Dec 26, 2014 04:28 PM
hotroddelux
Dec 3, 2014 11:33 PM
tC_Normo
Oct 22, 2003 07:20 PM
