PING Sid_xBicious AND / OR Tomas
Old Apr 18, 2006 | 06:04 PM
midtowndesi's Avatar
Default PING Sid_xBicious AND / OR Tomas
First off, I want to thank you both for contributing awesome info. on this board.
Secondly, I had a couple of "final" questions. I have ordered LEDs and am finalizing the way they are to be wired. I've come up with this quick diagram
that shows how i THINK i can hook up the LEDs to my dome light wires (so the leds will turn on/off a as the doors on my xb open/close.
*I am using 40k MCD (automotive use/12v) LED lights in the diagram.
My remaining questions:
1) Will I need a resistor (or more than 1 resistor) if I wire these LEDs in a series as shown in the diagram? If so, where will it/they be placed?
2) Will the power wires for the dome light support the "load" of the additional 18 LEDs that I plan on installing? Is there a possibility of blowing a fuse?
I think these are my last questions before I dig in and get this project started.
Thank you both, once again for your help!
- sh00k
Old Apr 18, 2006 | 06:20 PM
kkawana's Avatar
ok.. i know you asked for tomas or sid..... but i can answer one of those ?s you have
yes you should put a resistor inline with runs of lights... just to be safe.... a 1/2 watt should be more than enough.. 1/4 watt would probably work too.... 300ohm would a good starting point... higher resistance dimmer the lights
and each resister can be put any where in the series... start/end/middle/4 LEDs into it ect
not sure about the load of the exisiting wires tho...
Old Apr 18, 2006 | 06:24 PM
dgHotLava's Avatar
if the LED's do not have a built in resistor, you will need to add one.
it would be placed between the red and blue wire taps (not sure if those are the correct wires)
as for the correct size resistor, you need to figure that out.
LED's don't use much power, so yes the stock circuit will be fine
Old Apr 18, 2006 | 06:25 PM
dgHotLava's Avatar
also, just a note about how the LEDs will work.
they will not 'fade away' like the dome light. they will be on or off. no fading with this connection.
Old Apr 18, 2006 | 07:51 PM
Thanks Kkwana and HotLava for the information. I've updated the picture in my 1st post. Does it look good/correct now?
- sh00k
Old Apr 18, 2006 | 08:35 PM
dgHotLava's Avatar
yes.
Old Apr 18, 2006 | 08:40 PM
dgHotLava's Avatar
you could also just run all the positives to one point...
and all the negatives to one point.
this way if one LED burns out the others will stay lit.
this is called a parallel circiut
the way you have your diagram (series circuit) if one light goes out (goes bad) they all go out.
Old Apr 18, 2006 | 11:59 PM
kkawana's Avatar
looks about right.... go to umm... www.superbrightleds.com off the top of my head i believe somewhere on their site is a calculator that you input voltage and # of LEDs and it will spit out a resistor size for you... it may ask you a few other things as well...
and remember the LEDs do have a +/- to them... usually one side has a flat edge .... i believe flat edge= -(neg) so when you wire them up should be (+-)(+-)(+-) if done in series..
Old Apr 19, 2006 | 04:23 AM
Sciond's Avatar
good info!
Old Apr 19, 2006 | 10:37 AM
dgHotLava's Avatar
i couln't remember the site that did the calculation, thanks
Old Apr 19, 2006 | 11:47 AM
kkawana's Avatar
no prob....
happy bday
Old Apr 19, 2006 | 12:58 PM
ProshopXB's Avatar
no prob....
happy bday
It's been Dave's B-day for 6 months straight, how old are you now 125
But great info above, will be a lot of help to people asking these same questions.
Old Apr 19, 2006 | 01:21 PM
dgHotLava's Avatar
^^^ way to ruin my b-day.
Old Apr 19, 2006 | 01:57 PM
kkawana's Avatar
hmm.. come to think of it i think have seen the happy bday thing next to his name before.... probably told him happy b'day b4 too... oh well...
Old Apr 19, 2006 | 02:22 PM
lol @ the bday!
Just wondering though, someone on another forum mentioned that since I am running so many LED lights (18 of them), that i should be using a relay like the one that oznium sells: http://www.oznium.com/relay40 - Its called a 5 pin 40 amp relay.... I've hooked one of these up before when I installed fog lights into my old monte carlo.... but is this something i would need to wire the 18 LEDs to?
Does anyone have any idea if this is NECESSARY in my case? I know led's dont use a lotta power but it makes me wonder if 18 led's would be "too much" for the dome light "fuse" or wiring.... any thoughts?
thank you all once again!
- sh00k
Old Apr 19, 2006 | 02:51 PM
dgHotLava's Avatar
you do not need a relay.
LED's do not have that high of a draw to require it.
i'v got about 36-37 (keep forgetting) all on the same circuit...
Old Apr 19, 2006 | 03:16 PM
30 something? lol - wow, i thought my 18 was overkill
thank you again for the help and if i haven't said it already.... HAPPY BERFDAY!!!!
- sh00k
Old Apr 19, 2006 | 03:47 PM
dgHotLava's Avatar
yeah, 30ish...
anywhere i could fit some i hid them...
a friend has 56 LED's in there...but his are run off of the RS1 switch (cig lighter circuit) with cold cathodes and other stuff...
so, no problems with 18.
Taknitez
46
Sep 7, 2006 12:16 PM
Taknitez
Aug 29, 2006 10:00 PM
1ahBSP
Jun 1, 2006 05:07 PM
Tomas
Apr 30, 2006 06:36 PM
N9S15
Dec 27, 2004 03:27 AM
