whats wrong with my Teins/Drop
Old Apr 19, 2006 | 06:36 PM
jasonbegin's Avatar
Default whats wrong with my Teins/Drop
ok, so the car, was dropped yesterday on Tein htechs , i also had new rims put on, 18'
Today, i noticed something weird, when taaking RIGHT turns fast, Sometimes bumps, but mostly right turns, i hear this weird scrapping noise, but there seems to not be anything close enough to the tire, to make the noise? And it only happens when taking fast turns, and its deff coming from the right side? Whats going on? could it be the springs? i was told i would have no rubbing with these tires, normal 18's from Wheelmax.
Whats going onnnnnnnnnn??
Old Apr 19, 2006 | 06:40 PM
ack154's Avatar
I'm wondering if it's FAST turns or just a SHARP turn. Like if you drive slow, but crank the wheel all the way to the right... do you hear anything?
You shouldn't be having any rubbing with H techs...
PunkInDrublic's Avatar
I have the S-techs and I experience this sometimes, with 19x7.5 on 215/35/19 it can either be the wheel dipping into the wheel well and rubbing the plastic liner, or the wind deflector in front of the tire scraping the ground.
Old Apr 19, 2006 | 06:44 PM
ack154's Avatar
Ya... you could have a piece of the inner fender liner that's loose maybe.
Old Apr 19, 2006 | 07:27 PM
-NEMESIS-'s Avatar
what offet, width and tire size are you running?
Old Apr 19, 2006 | 08:32 PM
jasonbegin's Avatar
its same as stock, no clue what offset, i just ordered them, would that be on the tire ????
could the springs be in wrong?
Old Apr 19, 2006 | 09:07 PM
trdsparks's Avatar
I'm betting that you're rubbing. Probably just the fender liner. But what you should do is jack up the car and look at the fender liner for rub marks.
Old Apr 19, 2006 | 09:15 PM
brian's Avatar
find out what offset your wheels are...which you should've known when you bought it but oh well. also, what size tires are you running?
Old Apr 19, 2006 | 09:43 PM
jasonbegin's Avatar
35offset, running 18x7.5 on a 18' rim
also, That plastic around the Wheel, on the opposite side that i hear it on, its falling off a good inch, looks like i bottomed out and ripped out some bolts under my OEM Ground effects.. could this be it? its hanging, but the wheel still has a good 2 inchs away from it?
wtf.
Old Apr 20, 2006 | 12:31 PM
trdsparks's Avatar
That's probably what you're hearing. Tighten that liner back up and see what happens.
Old Apr 20, 2006 | 01:29 PM
ScionBandit's Avatar
sIcKsCiOnS
DelMarVa
Scion Tuners
fender lining rubbing, had same issue when i had my Stechs/TRD shocks Axis wheels
only on sharp or fast right turns at high speeds
it ran a hole in the fender lining and then stopped makin the noise
steeze69
May 24, 2021 02:57 AM
BlingSlade
Nov 20, 2015 06:56 PM
Klunkerbill
Nov 9, 2015 11:39 PM
Pkdust
Oct 20, 2015 04:27 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
