Maintiance Req. Light
Old Jun 4, 2004 | 04:19 AM
TakumiJr's Avatar
sIcKsCiOnS
Default Maintiance Req. Light
So, today the maintaince req. light came on (blinking) , which I have no clue of why . I just recently changed my oil and I just checked the Coolant level (resevior and rad.) and it was fine. I'm totally lost as to why the light comes on, so any help is very helpful. I'm going to let the dealer check it out also.
Thanks,
Old Jun 4, 2004 | 04:59 AM
BiggSlikk's Avatar
I had the same problem, just AFTER I had my oil changed. The manuel will tell you how to reset it. I think it comes on after so many miles to let you know to get your oil change (I think). Anyway, the manuel tells you how to shut it off. Its not real hard but it did take me a couple of attempts to do it. Good luck.
Old Jun 4, 2004 | 04:53 PM
Guest
Guest
Posts: n/a
the dealer is supposed to take care of that, but if they don't just reset it yourself. Hold the odometer button down and then start the car. Hold it down until the reading come up and then let go, the light will turn off and reset.
Old Jun 4, 2004 | 05:02 PM
snuppy's Avatar
that should work... just a heads up though, (i remember hearing/reading this somewhere) if your odometer is on one of the trip distance settings you might wipe out your milage info... so switch over to the actual odometer before you restart your car...
Old Jun 4, 2004 | 06:06 PM
ikhonlord's Avatar
I had the same problem after doing my first Oil change. I fixed it by resetting it the way the manual said. Also my light came of after 7500.....That one will not go out unless the service department clears it of the ECU.....
:D
Old Jun 4, 2004 | 06:16 PM
Huskersnow's Avatar
The light at 7500 can be reset by following the manual instructions. The dealer does not have to reset that one.
Old Jun 4, 2004 | 06:52 PM
ikhonlord's Avatar
I checked with the service tech and your right....Sorry! Misleading information!
Old Jun 4, 2004 | 10:03 PM
TakumiJr's Avatar
sIcKsCiOnS
Thanks, but I got the dealer to re-set it.
Old Jun 4, 2004 | 10:25 PM
TheScionicMan's Avatar
Tech Section:
Reset Maintenance Required Light
Contributed by eric m.
After you've driven your Scion for a few thousand miles, you will see a "maintenance required" orange light flash for a few seconds in the center display console every time you start your car. Do not be alarmed. this is just a reminder to have your oil changed. If you change your own oil, you can reset the light. here is how:
1. Turn on the ignition and make sure it is on your odometer display, not the trip display.
2. Turn off your ignition. Hold down the trip meter reset button and turn the ignition on. Keep the button pushed in.
3. The maintenance required light will flash for a few seconds. when it turns off, let go of the reset button.
The the display will change for 1 second and go back to the mileage. That's it.
https://www.scionlife.com/tech/elect...ance_light.php
Some other good stuff there too:
Old Jun 5, 2004 | 07:40 AM
XBman's Avatar
yeah that will work. Worked for me
Old Jun 8, 2004 | 10:12 PM
tCtech's Avatar
yeh, it comes on after 4500 miles of driving. just makes sure you're on odomoter mode, hold the button, start the car, let go when it goes out.
at the dealer we always turn it off for you, but there are the occasional slip ups. and occasionally the light comes on after it's been worked on so the tech never saw it.
xBSciontist
Jun 18, 2019 03:06 PM
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
