Skid plate for xB?
Old Apr 29, 2006 | 07:15 PM
Gothbox's Avatar
Default Skid plate for xB?
Does anyone make a skid plate for the xB I bottum out and scrape on most everything and would like a little more protection under there.
Old Apr 29, 2006 | 07:27 PM
Gothbox's Avatar
I already have a dent in my trans pan and the little braces behinde the front tire are looking kind of bad.
I will gat a few pics today to show how low it sits and maybe of the damage.
Old Apr 30, 2006 | 03:06 AM
Bsbox's Avatar
I've never heard of one for an xB but i would be interested too.
Old May 1, 2006 | 03:58 AM
TXboxdriver's Avatar
c-one makes one for the xA (ist)
http://www.c-one.co.jp/C-ONEPARTS/under_panel.html
don't know if it can be modified
just know that it will p1ss off your oil change guy.......
Old May 1, 2006 | 09:01 PM
Gothbox's Avatar
I will get some pics when it quits raining.
I have to change my own oil b/c it is so low that the cra won't fit over the gaurd rails or go on a lift. So it would only ____ me off.
Old May 1, 2006 | 09:24 PM
tikithed's Avatar
You could do like what we used to do our 4X4 's for rock crawling. Get a plastic 55 gal drum, saws-all a rectangle out of the drum & bolt it to the bottom of the xB. Large nylon cutting boards work well also. Do what ever is cheapest. If you weld 4 nuts to the bottom side & drill a thru hole for the bolt, you will have a good spot to put on & take the skid plate without stripping the threaded holes you put in.
This is only a suggestion. You mess up your ride it is your own fault. I take no responsablities for you mistakes.
Good luck
Old May 3, 2006 | 10:46 PM
Gothbox's Avatar
here are a few pics of some of the damage.
Darrenohooligan
Sep 26, 2015 07:21 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
Subaru86
Sep 14, 2015 12:43 PM
Subaru86
Jul 31, 2015 04:33 AM
herbn44
Jul 24, 2015 02:26 PM
