attempting to drop
Old May 5, 2006 | 06:57 AM
noribox's Avatar
Default attempting to drop
so my first attempt with the install of my tein Htech springs came to a bit of a halt...the entire strut came out with no problem...but when it came to dislodge the strut from the tower that's where i ran into the problem....as i tried to unscrew it...*with the spring compressed...the piston just spun...and nothing happenened...the screw didn't even come lose...it just spun the entire piston...granted i was using primative rachets and not impact tools...could this be the problem...or am i the first to run into something like this?...
any info would be greatly appreciated....
Old May 5, 2006 | 10:30 AM
craigxb's Avatar
whell first off. you might need to hold the shaft of the strut with a clap or pliers. just to break the nut. then it should come out after that.
Old May 5, 2006 | 11:46 AM
dugzilla's Avatar
If you take a rag and wrap it arount the piston and clamp it with a pair of vice grips you should be able to remove the nut.
Old May 5, 2006 | 03:54 PM
noribox's Avatar
thanks guys ill try that and let you know how it goes...i was thinking about that...but i didn't want to potentionally bend my piston...
Old May 5, 2006 | 03:56 PM
hayalex6's Avatar
I didn't use spring compressors when I did mine, and my eyes are still here.
Old May 5, 2006 | 04:00 PM
dugzilla's Avatar
what are you talking about?
Old May 5, 2006 | 04:03 PM
superfreestyle's Avatar
DeepSouth Scions
i have done many of these.....
you must remove the nut with an impact wrench with the spring un-compressed, it will not fly away and hurt someoneit will only spring outabout 10 inches at most.
Old May 5, 2006 | 04:05 PM
DeepSouth Scions
BTW i have done 8 spring swaps on xb's, one accord, and one supra
hayalex6's Avatar
That's what I'm talking about.
I'm thinking if there was load on the strut, then the whole assembly wouldn't spin.
Old May 5, 2006 | 04:13 PM
noribox's Avatar
how much of the bumpstops did you cut...or did you guys cut any at all?...or just remove the whole thing...i know when i had my prelude and integra..<--back in the highschool days...i took them off completely on the prelude..and the integra i cut about 3/4 of an inch off it...
Old May 5, 2006 | 04:18 PM
dugzilla's Avatar
I was refering to the eye comment, if you read the DIY it says to loosen the nut (not take it off) before you remove the strut. You don't have to use an impact wrench, my hand socket worked just fine.
Since he had already removed the strut and has the springs compressed we gave him some tips.
when I changed the struts on mine I could not get the nut on all the way because the piston was spinning, so I took a rag and my vice grips and it worked great.
rvascion
Nov 12, 2020 03:23 AM
BlingSlade
Nov 20, 2015 06:56 PM
ScionLife Editor
Sep 24, 2015 10:50 PM
Kennedylikethepres
Sep 15, 2015 10:47 PM
user9430961
Sep 15, 2015 03:16 AM
