XM Radio XPress
Old May 8, 2006 | 02:46 PM
clockwerk's Avatar
Default XM Radio XPress
I have a XM Xpress and i want to put it into my Scion. Does anyone have any directions on how to take apart the everything that is needed to get behind the radio and pictures of the back of the stock radio (w/o ipod).
Old May 9, 2006 | 04:22 PM
DannyC's Avatar
Default 05 or 06
Is yours a 2005 or 2006 Scion radio? I own a 2005 tC and I have added the Toyota XM Radio part to my tC. I have the instructions on how to install that part, and I could probably take some pictures on how to remove the front dash (It is really easy). But I don't know how different the connectors are between the '05 radio and the '06 radio. Just let me know if any of the information will help.
Old May 9, 2006 | 07:03 PM
clockwerk's Avatar
i got an 06
i dont think the dash is that much different, if you wouldnt mind taking the pictures it would really help out a lot
Old May 9, 2006 | 07:22 PM
NoLimitzBuilt's Avatar
Team No Limitz
it is the same.. really really easy to do.. the connectors are the same as well on the back of the radio.
The area around the shifter has to pop up and pulls away from the dash area. Then you can grab the dash bezel and you should be able to pull it off the dash, it just snaps on. There is a single harness that is plugged into this bezel, that runs the HVAC. Then the radio is held in there with two phillips screws at the bottom and 2 10mm bolts on the top. The whole bracket assembly will come out at that point.
Old May 11, 2006 | 07:25 PM
DannyC's Avatar
Default Some pictures
I have put together a very "rudimentary" instructions, Sorry for the wait but I had ordered a new Head Unit for my scion and I was waiting on the part. Below is a link, In time i will redo the pictures and I will revise the text.
http://www.liberty.k12.mo.us/~dcarter/scion/
I will work on scanning in some of the manual I have later on.
prescottn
Oct 8, 2015 05:31 PM
dyenfd
Sep 13, 2015 10:00 PM
rhino8648
Sep 6, 2015 04:04 AM
10spokess
Aug 16, 2015 02:50 AM
semlin
Jul 29, 2015 02:07 AM
