stock system problem
Old May 3, 2006 | 01:49 PM
Tylerwashere's Avatar
Default stock system problem
I just got my tC and it seems that when I accelerate the sound quality changes and the bass increases, anyone else have this problem?
Old May 3, 2006 | 02:04 PM
ack154's Avatar
It's not a problem. It's speed-sensative volume. You should adjust the sound while you're moving (safely ) and it'll get softer as you slow down and louder as you speed up. It's a 2006 thing.
Old May 3, 2006 | 04:11 PM
Borisimo's Avatar
You can disable if too if you dont like it, its the ASL setting on your HU.
Old May 3, 2006 | 04:51 PM
how do you disable it?
Old May 3, 2006 | 04:54 PM
SquallLHeart's Avatar
press **** to go thru your options.. just like changing your bass, treble... etc... and rotate to change.
Old May 3, 2006 | 05:14 PM
Tcjake's Avatar
you can also adjust the sensitivity too. I think it has Hi Med Lo setting.
Old May 3, 2006 | 05:21 PM
i could always just say read the manual (for the head unit)... it explains everything and what it does.
Old May 3, 2006 | 05:25 PM
ha, thatd be too easy
thanks everyone
Old May 3, 2006 | 07:53 PM
06bspTCkid's Avatar
not to steal your thread but idk if this has been posted or not but if you hold down the SSP button than you can change your vehicle type from tC to xB and xA and xA seems to sound a lot better...kinda kool deal for me
Old May 3, 2006 | 07:58 PM
ack154's Avatar
I believe theirs an article on that in our Tech section... Click Features up top, and then Tech.
Old May 6, 2006 | 03:31 AM
Phixeus's Avatar
i think it works on the other years also! buddy has 05 and his has VAS (that little thing that adjust your stero vol based on either ambiant noise or car speed and engine RPM.) there are a few diff names they refer to it as so mine in not 100% accurate across the car manufac. board!
Old May 11, 2006 | 05:03 AM
ismael3d's Avatar
Does anyone have a link to the manual for the Stock 06 HU? Pls post if you do, im looking for some info on it to see what my possibilities are with it before i decide what im gonna do with it on my budget.
Old May 12, 2006 | 12:10 AM
Phixeus's Avatar
post what you wanna do and then we can tell you if it will work! its har to go the other way around!
Old May 12, 2006 | 04:10 AM
ismael3d's Avatar
well, i basically want to know what my options are for putting in 2 12"s i had in my old civic and want to know what im going to have to do to get it in and if its going to cost me a few extra bucks . Is there an output on the HU itself or am i going to have to take my feed from somewhere else such as my rear speakers?
Im also aware there is a wire harnes for the farctory bazoka that comes as an option and am currious to know if i might be able to rig something up if i were to get one so that i can keep the screwing with the existing wiring to a minimum. Reason for me not wanting to mess with the existing system so much is because being my first new car im not entirelly sure how messing with the sound system will affect warranty and such.
Worse come to worse i will have to switch out my entire HU but i know if i end up having to do that im going to want to go all out with it and im trying to keep myself from going that way atm .
Beesh
Jan 9, 2015 06:30 PM
spawnconnery
Dec 18, 2014 08:38 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
