Drag Strip Tires
Old May 12, 2006 | 10:14 PM
Nick06tC's Avatar
Default Drag Strip Tires
Ok I am totally dissapointed with my 14.9 at the drag strip so I need tires. I am going to use two of my stock wheels to put some grippy tires on them. I searched online to see what I can get, now I need to know what people reccomend.
Here is what I found. Can someone WITH KNOWLEDGE OF THE SUBJECT tell me what is the best for the drag strip once a month or so.
Oh and what size do you reccomend for the stock 17's? Should I stick to 215's or can I stretch to 225s?
Nitto Nt-01 225-45-17 $166 http://www.discounttiredirect.com/di...tp=Competition (they only come in 205 or 225 or bigger)
Nitto NT 555R Drag Radial 245-45-17 $145 http://www.discounttiredirect.com/di...tp=Competition (only size even close)
Yokohama ADVAN A048 215-45-17 $219 http://www.tirerack.com/tires/Compar...None&x=33&y=10
Or can I just get an Ultra high Performance tire for cheaper and get good results. I have been doing alot of research and now need opinions.
Thanks in advance.
Old May 12, 2006 | 10:16 PM
ack154's Avatar
Are you still on stock tires now?
Old May 12, 2006 | 10:22 PM
Nick06tC's Avatar
No I am on 18's. With Kumho tires, that I might add SUCK SUCK SUCK.
I am thinking of trying my stock potenzas at the track, but I dont think they would be much better than my 18's. They have been sitting out back since the day I got the car, and I need to put them to use. So I figured to super sticky ones would make my times better.
Old May 12, 2006 | 10:29 PM
ack154's Avatar
Heh... no, I wouldn't bother with the Potenzas if I were you.
I've heard good things about the BFG DOT Drag Radials though... I know Tirerack sells them.
Old May 12, 2006 | 10:35 PM
Nick06tC's Avatar
These ones:
BFGoodrich g-Force T/A Drag Radial Tires 225-45-17 $137.95
http://www.strippermotorsports.com/bfg-54458.html
Old May 12, 2006 | 10:57 PM
ack154's Avatar
Those are the ones... I think Kaeon put them on his fronts as well... if not him, someone else... b/c there was a thread about it a while back.
Old May 12, 2006 | 11:02 PM
mandangalo's Avatar
Those BFGs are awesome, especially for the price. i borrowed some last week from a friend with a neon turbo.
Old May 12, 2006 | 11:37 PM
Nick06tC's Avatar
I might order a set tomorrow
Old May 12, 2006 | 11:41 PM
ack154's Avatar
If you want to be sure, I'd wait for a few more replies... but I think at the VERY least, these would be a pretty good jump up from the tires on your 18s. And they're pretty decently priced.
And on tirerack, they're a few $$ cheaper, but I don't know about shipping.
Old May 12, 2006 | 11:46 PM
Nick06tC's Avatar
how did you fidn them on tirerack? I could only find two comp tires for crazy prices? Do you have a link? I am good at finding stuff but couldnt find them.
Old May 12, 2006 | 11:58 PM
nodsetse's Avatar
Here's the link to the original T/A Drag Radials;
http://www.tirerack.com/tires/tires....FA+Drag+Radial
And here's the link to the new T/A Drag Radial 2;
http://www.tirerack.com/tires/tires....+Drag+Radial+2
If you want to drive with your 1/4 mile tires on the street, either of the above are your best bet. However, if you don't mind changing your front tires at the track, you might be better off looking for some slicks that'll fit the stock 17" rims, or even finding some 15" steel wheels to mount slicks on.
Old May 13, 2006 | 12:05 AM
Nick06tC's Avatar
Thanks for the links. I dont mind changing at the track because its an hour drive and I wouldnt want to put to much wear on the drag tires. I will search for slicks. as well.
Any more input anyone? I need to get my times down.
Old May 13, 2006 | 02:08 AM
tikbhoy's Avatar
dude 14.9 is not too shabby with those rims of yours. im around that number with stock tires and higher elevation.
did you play around with the tire pressure ?
you werent dippin it on the waterbox ?
i would just use the stock rim and add 225's drag radial.
Old May 13, 2006 | 04:11 AM
scrap's Avatar
I want to drop down to a 15 in rim and throw some BF goodrich drag radials on. I think a smaller wheel with some grip will help my #'s. Thats my plan.............. I think a corolla rim will work.
Old May 13, 2006 | 07:21 AM
Nick06tC's Avatar
My wife has a corolla, I wonder if she would notice if I put m tC rims on hers and used her rims with drags on it
Old May 13, 2006 | 05:34 PM
TCTuNeR80's Avatar
Dunlop just came out with is new line of tires, DIREZZA, they make DOT drag radials check into them, you never know, worth a shot
Old May 13, 2006 | 05:50 PM
Nick06tC's Avatar
I will search for them now.
Old May 14, 2006 | 04:19 PM
TCTuNeR80's Avatar
Did you ever check on the dunlop direzza radial? If so what did you think i've been curious
Old May 14, 2006 | 05:49 PM
Nick06tC's Avatar
Check this chart out it shows them
http://www.racegoodyear.com/pdf/2006...k/dot_drag.pdf
evolving_machine
Oct 21, 2023 01:16 PM
Erager09
Sep 26, 2016 03:11 PM
Fisqual
Sep 22, 2015 05:51 AM
Erager09
Apr 26, 2015 12:50 AM
cb900f2
Scion tC 2G Aero & Exterior
Dec 14, 2014 10:46 PM
