xa throwing cel
Old May 14, 2006 | 05:22 AM
Esc8p2NeverLand's Avatar
Default xa throwing cel
The car is throwing a light and won't rev past 3000 rpm. The codes it threw re p0103 and p0101. Any ideas what happened? The car has intake and header so far.
Thanks
Tyler
Old May 14, 2006 | 07:46 AM
OldYeller's Avatar
How long ago did you install the intake? I read a post earlier today, which I can not find now, that talked about creating a short between the battery and the intake. It fried some sort of sensor on the intake and the car would not go past 3000 rpms after that. Sounds similar.
Old May 14, 2006 | 07:52 AM
OldYeller's Avatar
OK--found the thread:
https://www.scionlife.com/forums/vie...=intake+sensor
Old May 14, 2006 | 09:08 PM
the intake was installed about a month ago. Oh and this all happened yesterday after installing some fog lights.
Old May 14, 2006 | 10:02 PM
frogbox's Avatar
first, try resetting the ecu
second, did you clean the inside of the intake before install?
third, alot of times the MAF sensor gets contaminated with oil from the new filter, could take a month to throw the cel.
you could try cleaning the maf, but be very careful, it is fragile as a hymen. use electronic parts cleaner, but not a direct pressure spray on it, let it dry and re-install.
while you are doing this, if you disconnect the negative battery cable it will re-set the ecu.
good luck, and following these instruction are at your own risk, I did it with no ill effects, but I did it on mine so nothing ventured nothing gained.
Old May 15, 2006 | 01:08 AM
thanks for the help guys. I'll try cleaning it. IN fact I was going to, but for the life of me, could not find my electronic cleaner.
Tyler
yupinmytC
22
Jul 27, 2024 07:08 PM
eujin
Feb 23, 2016 01:18 AM
MeDizzy
Oct 8, 2015 03:31 PM
Gigs
Sep 15, 2015 03:54 AM
crimson10tC
Sep 10, 2015 08:44 PM
