Think about getting this sub....
Old May 15, 2006 | 10:15 PM
TcGUY211's Avatar
Default Think about getting this sub....
I am planning on getting one 12 inch alpine type r sub. I was wondering what one the get the 4q+4q or the 2q+2q? What amp should i get with this sub? Also what enclosure should i buy a bandpass or a regular one? Also i will be hooking it up to my stock head unit. Thanx.
Old May 16, 2006 | 07:27 PM
SCI_TC_GUY's Avatar
the VC configuration depends on the amplifier you're going to get. If the amp puts out it's highest wattage at 1 or 4 ohm mono, you'll want the Dual 2ohm VC... if the amp puts out it's highest wattage at 2ohm mono, you'll want the Dual 4ohm VC....
I would definitely stray away from bandpass enclosures. Look for a sealed box with an internal volume within the specs of the sub. OR, have a ported enclosure built that is TUNED around 30Hz and built to the t/s parameters of your subwoofer...
Old May 16, 2006 | 11:09 PM
ihaveatc's Avatar
sealed box within the cpexs just like i have
ihaveatc's Avatar
Old May 17, 2006 | 02:30 AM
TcGUY211's Avatar
I went the 6th ave electronics, and was listening to the alpine typer swr1242D with differnt amps. I decided the the best sounding one was the alpine swr1242D 12 inch sub with the jl audio 500/1 amp, and a ported box. They were charging an arm and a leg for the system, so does anyone know where i can pick this equipment up for cheaper.
Old May 17, 2006 | 10:49 AM
ihaveatc's Avatar
EBAY
Old May 17, 2006 | 11:32 AM
SCI_TC_GUY's Avatar
Indeed.... or www.woofersetc.com
You need to know, though, that JL doesn't authorize ANY online sales... this means that if a JL product breaks that was purchased online and you try to send it back to JL for repair, you're going to pay out the bum for re-serialization and rebuild.... that being said, I've bought JL products online before and not had a problem with the quality...
XBTWEEKSTARXB
May 20, 2004 02:38 AM
