I need help, for real!
Old May 16, 2006 | 08:21 PM
06tCpimpn's Avatar
Default I need help, for real!
Alright so today I finally had off work and decided to put on my foglights...everything was going great until I put the battery back together and trying to roll up and down my passerger side window...it didn't roll up or down, only by using the passenger side switch you can roll it up and down but no auto roll up or down...it's the same on both sides and the sunroof i have to use alot of force for it to act right...can ANYONE PLEASE help me, is there a fuse that I could not find or a wire to check...please help a fellow brother OUT!!
Old May 16, 2006 | 08:23 PM
azuresky's Avatar
Well, I will tell you what most people are going to reply with... search the forums.. this topic comes up quite often.
But then, since I am not mean... I will also tell you that you need to roll the passenger side window down, then put it back up and hold the button up for several seconds. After that it should be reset. It happens every time you disconnect the battery. It is in our owners manual for the car.
Old May 16, 2006 | 08:27 PM
kjmira's Avatar
Big Sky Scion
You need to reset them. You will have to open them several times from their own toggle. Once you get the passenger side to "auto-down" from the passenger side toggle, you will be able to "auto-up/down" from the driver side. This will also need to be done for the sunroof. I've had to do this every time I've disconnected my battery. Good luck.
Old May 16, 2006 | 08:29 PM
tikbhoy's Avatar
i think i freaked out too, when it happened to me before.
but i called the dealer and they told me whats up.
Old May 16, 2006 | 09:13 PM
06tCpimpn's Avatar
thanks fellas! Yeah i was just kinda worried because i did not want it to void my warrenty...but thanks for the help, sorry i tried looking for this thru search, didn't look hard enough apperently! But regardless, thanks!
Old May 16, 2006 | 09:16 PM
yellowxboy's Avatar
lol glad you fixed it!
i was scared sh*tless when i had to restart my ecu cuz i installed my weapon r intake and my windows didnt go up and stuff. LOL
Old May 16, 2006 | 09:21 PM
SushiFish's Avatar
You may also want to check the sun roof...I've had to reset my sunroof after disconnecting my battery.
To reset the sunroof just turn the car on, hold the sunroof button towards off or a few seconds. You'll hear a noice and your sunroof should be working.
Old May 16, 2006 | 09:32 PM
engifineer's Avatar
look in your manual for instructions on how to reset everything
Old May 16, 2006 | 10:48 PM
BuddhasTC's Avatar
same thing happened when i installed my Injen CAI and it just started working again 2 days later without resetting it. If worse comes to worse, it could have been taken to the dealer to get fixed...they can't prove that your foglights caused your windows not to work.
BlingSlade
Oct 19, 2016 12:39 AM
greytc
Oct 26, 2015 07:53 PM
JonnyBigBoss
Sep 26, 2015 08:31 PM
mxwes
Aug 30, 2015 09:11 PM
dbg326
Aug 28, 2015 05:18 PM
