Noise when you start the engine
Old May 17, 2006 | 10:16 PM
dxallydx's Avatar
Default Noise when you start the engine
I don't know if this is the right place to post this but does anyone have a problem when they start up the engine in the morning....it's not smooth and make this like choking noise. I don't know how to explain it but it's not smooth. But after I start the engine...in the afternoon it start smoothly. My Co Worker have a tC too and It's doing the samething. Anyone have the same problem? or know how to fix it?
Old May 18, 2006 | 01:07 AM
Neothin's Avatar
my car always runs like crap for the first couple of minutes after the first startup in the morning. Shifting is rough, the engine takes a little longer to rev up, etc etc. if that's what your talking about, that's normal IMO because another guy that i know has said that his car does the same thing.
Old May 18, 2006 | 02:23 AM
njdan69's Avatar
ScionERA
I had the same problem when I put any gas in above 91 octain. maby thats it
Old May 19, 2006 | 05:00 PM
gizmo's Avatar
OMG i have the same problem.. and i have been scared for a month now thinking my car was going to break down.
Should i take my car to the dealer to have them check it out or take a look at it. Its a 2006, it should start so shaky like that.
Old May 19, 2006 | 05:13 PM
ack154's Avatar
Which just goes to show you should actually stick with what is recommended for your engine.
87.
Putting in anything higher will no give you more power and may actually cause problems. If the care needed anything higher or ran better on higher octane, they would have recommended it.
Old May 19, 2006 | 05:20 PM
sako's Avatar
aCtually ive been gettin problems just starting the engine period. It seems to stall for a second then it starts. I have many friends that have tc's around here, and one of the, actually told me something about the fuel lines. That when at night when we turn of the car, the fuel doesnt go back....it stays in the pipes, so by morning its bad or something....idk lol does that sound right?
Old May 19, 2006 | 05:26 PM
coppermine18's Avatar
I've noticed if the air is warmer mine will not run as well.
After the I/H/E it will start 1st turn perfect - when it gets warm it wants to not start the first turn then starts normally.
Old May 19, 2006 | 05:29 PM
TempleOwl's Avatar
This issue was already discussed in a previous discussion. I have the same issue and it seems to be common and normal.
Old May 19, 2006 | 05:30 PM
ack154's Avatar
^ I wouldn't believe any fuel would go bad overnight. Sounds like BS to me.
If it seems to stall for a second, make sure you have the clutch ALL of the way down (if it's a 5spd). It will fail if you let off too soon.
Old May 19, 2006 | 05:40 PM
I have my Injen CAI - DC Sports Header and a full 2.5" Exhaust and Injen Axleback... The problems started after all 3 mods were done and I found out it was not fuel that caused it.
The problem is when the car starts it reads incredibly lean. After it reads lean it doesn't know what to do so it just 'dumps' fuel.
If you have IHE upgrades you really should get something to manage the fuel.
Old May 19, 2006 | 06:59 PM
TempleOwl's Avatar
Actually that's right. It's the fuel pump. I tried it and haven't really had much of a problem since. I took it into Toyota and they couldn't figure it out. Just turn on the car for 2 to 3 seconds then turn the ignition on and it should catch right away.
Old May 19, 2006 | 10:52 PM
gizmo's Avatar
My dad, whos a mechanic said that you should put the key in and turn it only till pint you hear the 3 or 5 rings. Becasue the fuel line or pump is filling (or something like that) during those beeping sounds. then turn the engine on. When i do that it starts fine - but damn it when im late for work i dont have time for that ____ - and i feel a new car should start automatically with no problems whether u wait for the rings or not!! Who is with me?!!....
Old May 20, 2006 | 02:41 AM
sako's Avatar
i totally agree with u..... but yeah i think what he said is that its the fuel pipe, u were right TempleOwl. And i do drive an automatic... the only place it can b is in park lol, i hope the recall it, maybe install a new fuel pipe......
Old May 21, 2006 | 05:13 PM
gizmo's Avatar
Yea mine is also an automatic. You know what im going to be making a phone call tomorrow to my dealership and see what can be done -because its obviousely a problem if a bunch of us have the same complains!! ill update you guys.
Old May 24, 2006 | 05:46 AM
Frisk00Azn's Avatar
For me when i start the car in the morning it seems to be fine. All i hear is a clicking sound. And that is normal for cars,
Jordly221
Feb 13, 2019 05:29 PM
meowtc
Mar 5, 2015 02:28 AM
cid_mcdp
Jan 5, 2015 02:45 PM
eric_m
79
Mar 17, 2013 12:21 AM
randode
24
Nov 20, 2003 10:58 PM
