Help. new HU install...AC lights now gone
Old May 19, 2006 | 04:46 AM
qrymson's Avatar
Default Help. new HU install...AC lights now gone
so yeah. i buy a great new HU and now my lights for the ac control panel are now off. its wierd, check it out.
had an old system with amp no subs then the Hu died. rewired with Line out convertors and put stock Hu back in. now have new HU and installed new wiring harness and tapped back in. taking out the line out convertors and taped backed up. put it all back togetherand noticed this.
put the key in turn on the car the backlight for the clock turns on like it should. but when i turn on the headlights the clock light goes out and the backlights for the buttons don't light up. pressing the buttons for reardef and the others light up when i hit them. checked the connections. fine. disconnected the battery hoping that would do something. nay. has anyone run into this? should i just take it to dealer?
Thanks for the help.
Old May 19, 2006 | 02:50 PM
qrymson's Avatar
no one?
Old May 19, 2006 | 03:07 PM
mandos's Avatar
Well...I was going to suggest making sure the thing was clicked all the way in in the back...that's about the only thing I could think of if you ONLY changed the HU.
All the AC wiring is handled through a separate harness that you have to pull when removing the top part of the center console. Check fuses and make sure that the connector is pushed to the point of going...CLICK.
Then take it to a dealer if it doesn't work.
Old May 19, 2006 | 03:36 PM
Forklift's Avatar
sounds like you blew the dash lights fuse or rheastat(sp), the dimmer control piece. Id check fuses and make sure you didnt ground the radio to the dimmer wire instead of ground, a common mistake
Old May 20, 2006 | 02:08 AM
qrymson's Avatar
cool thanks for the help guys. we did check for a loose connection at first and it still didn't work. i'm calling the dealer monday. poop.
Old Nov 10, 2006 | 02:15 AM
rrimportracer's Avatar
check your fuses
Old Nov 10, 2006 | 02:18 AM
dugzilla's Avatar
What HU did you get Andrew?
Old Nov 10, 2006 | 02:26 AM
L8u8k8e8's Avatar
Thread back from the grave....
Old Nov 10, 2006 | 02:35 AM
so i just wanted to know if he still had the problem and if he did then check the fuse, if not what fixed it im trying to figure it out for a friend of mine
Old Nov 10, 2006 | 04:14 AM
crowboy164's Avatar
I just figured out what did it on my car. Was going back over thr wiring with a fine tooth comb and didn't realize there were 2 ilumination leads on the toyota harness. 1 positive and 1 negative.... not playing close attention when wiring i presumed one was on the HU since i'd never seen 2 on a factory harness and wired them together. will check my fuse box in a few and see what i blew.
Old Nov 10, 2006 | 06:00 AM
qrymson's Avatar
hey look at that. it's alive.
so yeah i kept putting it off to have it fixed. going to get around to it again. will check crowboy164's idea tomorrow. i recall seeing the 2 leads also. hmm...if not that, i'm going in next week for some service and am having it checked out.i'll post up when i find out
Old Nov 25, 2006 | 04:23 PM
Zangetsu's Avatar
any luck having that issue resolved?? I'm having a similar issue with my hvac. I replaced the leds and now its dark...only the indicator leds for the ac, defrosters, etc. light up
Inazuma
20
May 3, 2023 01:58 AM
merotty
9
Mar 9, 2015 05:27 AM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
greytc
Jan 12, 2015 09:49 PM
carid
Jan 8, 2015 11:33 AM
