HID Retrofitting-Can someone point me in the right direction
Old May 22, 2006 | 11:39 PM
Burn0ut's Avatar
Default HID Retrofitting-Can someone point me in the right direction
So i'm thinking about doing a HID retrofit into a stock housing. I've done some research on scionlife as well as other websites (hidplanet and hidretro) but I'm still a bit confused on the details. I'm planning on taking stock housing and painting the side black...then using the projectors and hid system out of a tsx or something along those lines inside of the housing. To my understanding painting the inside black will eliminate the weird pattern you get with plug and play kits, but I also read that you need a block off plate for the back to make it flat (is this true?). Other than that am I missing anything for the physical build of the system? And how goes the wiring of another car's hid system into the xB. Any help would be appreciated.
Old May 23, 2006 | 03:35 AM
chipzxb's Avatar
You have is pretty much summed up. As for the wiring make sure you get a relay harness. And go with the oem equiptment not a kit.
Check out this site it's really helpfull..
http://faqlight.carpassion.info/
PM me if you have any questions , I did mine myself also..
Old May 23, 2006 | 04:41 AM
Burn0ut's Avatar
good info thanks!
Old May 23, 2006 | 08:19 AM
mat18's Avatar
make sure you do a write up on this. Because I need some help on this.
Old May 23, 2006 | 09:01 AM
Burn0ut's Avatar
im still in the thinking it through process....$500-$600 is something i really need to think hard about...lol
Old May 23, 2006 | 10:51 AM
mat18's Avatar
Im in the brainstorming process right now too!! I was thinking about some BMW projectors or S2000. BMW are much cheaper.
evolving_machine
Oct 21, 2023 01:16 PM
lovemyxb333
Apr 3, 2015 01:40 AM
tc_Jake
Dec 31, 2014 01:45 AM
supaguy
22
Feb 26, 2004 06:53 PM
cody
Feb 18, 2004 05:15 AM
