Key Quest
Old May 23, 2006 | 04:54 PM
mildmodtc's Avatar
Default Key Quest
I did a search before posting and couldn't find information I was looking for. I lost one of my main keys and had a new one cut. I'm hoping anyone on here would know what the sequence to reprogramming the key is.
Thanks in Advance!
Old May 23, 2006 | 04:59 PM
Ghost_1's Avatar
this is for the xB but it might possibly work. . .
https://www.scionlife.com/forums/viewtopic.php?t=16563
Old May 23, 2006 | 07:54 PM
Rabid_Lemming's Avatar
Default Re: Key Quest
Thanks in Advance!
I thought the keys had an RF id? If you just had a copy made at a key maker, it'll fit but won't start the car (right?) They gave me a little metal plate with a number on it, so if I needed a new key, I'd have to get it from Scion in order for the RF codes to work. If this isn't what you meant, sorry for the wasted post and time.
Old May 23, 2006 | 09:51 PM
JaeSin's Avatar
The keys r made with a transponder by texas instruments, the TC's dont have On-Board Programming...that i kno of....its done by a machine that copies the code from your original key, then u insert the blank key and it writes the code onto that key...a locksmith or a hardware store wuld be able to do it cheaper than the dealer...not all stores do it tho, i manage a hardware store and i just got the machine in....i charge about 35$ for them....
Old May 23, 2006 | 10:09 PM
watcher1307's Avatar
Wow, Iwas told that my dealer charges 80 bucks for one.
Old May 23, 2006 | 10:19 PM
SquallLHeart's Avatar
yeah.. moral of story... don't lose your keys.
Old May 23, 2006 | 11:30 PM
farberio's Avatar
ANYTHING OVER $100 FOR A KEY IS BS!!!
http://www.keylessride.com/order/quo...&frid=76C74C4F
Here is a key for $85. Ask your dealer to program it to your car or use the instructions they send you.
Now...
The keys have unique transponder in the fob that is programmed by the CAR. This transponder ID is learned by the car and is used by the immobilizer system. So if someone has a key that matches your car but the transponder is not learned the car will stall out to prevent theft.
The buttons are worked by a seperate system with a battery. They are also programmed where the key electronics is manufactured, not at toyota. The buttons also have a unique ID learned by the car. (The reason my fob wont unlock your car)
The transponder is powered up by a coil around the ignition through LF (Low Frequency). This way when your tiny key fob battery dies you can still start the car without it stalling.
You better have engineered the keyfob if you wish to argue as I make keyfobs at work and know whats up
Old May 23, 2006 | 11:38 PM
jbae1221's Avatar
wow... that's all i can say is wow...
Old May 24, 2006 | 12:37 AM
Yup.......wow.
Old May 24, 2006 | 01:27 AM
farberio's Avatar
btw, mods can you put that website somewhere sticky. like in a where to go if you lose your keyfob FAQ?
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Nov 20, 2015 06:56 PM
neneago
Oct 27, 2015 04:47 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
Geedavell
Scion xD ICE & Interior
Sep 28, 2015 01:33 AM
