19 or 18 inch?
Old May 28, 2006 | 04:12 PM
DonnyDarko's Avatar
Default 19 or 18 inch?
i cant decide!!! Im saving up money for some new shoes, but im not sure which size would look better!!! 19 inch or 18 inch.....please post ur opinion! O and show me some pics of your rims if you wish
Old May 28, 2006 | 04:14 PM
reckless's Avatar
If you are going to have springs on, I would recommend 18s. 19s will look good tho, just don't lower it too much.
if you see my profile, you can see my setup
Old May 28, 2006 | 05:06 PM
KickAssKishan's Avatar
Id say go with 18s..
18's + S-techs > 19's + trd springs
thats just my oppinion
HOWEVER!!!
there are def exceptions! like WDS's tC...bc he def is pulling it off...ive seen some others too though
but what rims are u looking at to buy? figure that out first
Old May 28, 2006 | 05:12 PM
DonnyDarko's Avatar
Well i was looking at something along the lines of this...
http://cgi.ebay.com/ebaymotors/18-DR...69467706QQrdZ1
Looked pretty clean in my opinion.
Old May 28, 2006 | 05:23 PM
yeah bro those are very clean...i like them alot...
go with the 18 and get s-tech springs
u wont regret it
Old May 28, 2006 | 05:28 PM
PunkInDrublic's Avatar
19's + s-techs > 18's + s-techs
Although I'm a bit biased.
Old May 28, 2006 | 06:48 PM
but isnt that just going to give him problems with rubbing?
like soo much to where the car isnt fun to drive?
and yes im asking u a question not trying to call u out..
Old May 28, 2006 | 07:14 PM
Running 19x7.5 et 42 215/35/19 ... the only rubbing issue I have is when I hit a dip in the road going fast, my fronts rub a bit on the inner plastic lining. No biggy IMO. Otherwise, I don't have any rubbing issues.
Just get the right offset and 19s will be fine.
Hell theres a guy on SL, don't know the name off the top of my head, but he's from Arizona that is running 20s on S-techs and he has no issues either.
Old May 29, 2006 | 01:24 AM
Hyghgynx's Avatar
I have 18s with TRD Springs. I guess it all depends on what you want to do with your car. Do you want it for 'show'? Or do you want it for 'performance'? Lots of peeps will say not to go past 18s if you're going the 'performance' route. (Most will say stick with 17s.) I went with 18s because my tC is a daily driver and I don't plan to SC/Turbo it. Here's a pic...
Also, TRD Springs won't wear out your shocks as quickly as some other Springs will. I don't rub either. (And we have some pretty crappy roads here.) The stats on my set-up is 18" 5Zigens RX-6 +35 w/Pirelli PZero Nero M+S 225/40s. I think its swell!
Old May 29, 2006 | 04:22 AM
brian's Avatar
they're going to be extremely heavy, so if you're going for performance go with 18, or even a lightweight set of 17s.
if you're just going for looks, go with 19s.
Old May 29, 2006 | 02:11 PM
DonnyDarko's Avatar
Alright 18s with s-tech springs it is!!! Sounds very good....how much would those s-tech springs cost?
Old May 29, 2006 | 05:30 PM
brian's Avatar
springs should probably be somewhere around $150, but you may want to get some shocks as well. i'm assuming you'll be doing the install yourself?
Old May 29, 2006 | 05:37 PM
Kilo6_one's Avatar
Ive done both.......originally i had axis sevenmods and they were heavy and casued some noticable lag and issues when i braked (sloppy) i switched to 18's due those issues. 19's look good.... however my recomendation is if you go 19"s at least upgrade your brakes.
Check my profile i think i have pics of both set ups.
also total rotating mass is about 50-55 pounds including tires and air.......that is almost twice what i have now (18's)
Unless you spend some money and get some forged or other lightweight wheel in a 19" fittiment you will have some performance loss.
Old May 29, 2006 | 06:32 PM
Infamous_Scion's Avatar
19's look good 18's are safer
Old May 30, 2006 | 12:07 AM
StyleSupremacist's Avatar
well the thing is with performance.. smaller tires are better since you get faster acceleration... bigger tires higher top speed
Old May 30, 2006 | 04:46 PM
Also 18's are easier to find than other rim shops
Old May 30, 2006 | 07:59 PM
yadeadson's Avatar
20's and cut the stock springs... Uhhhhhh
Old May 31, 2006 | 01:32 AM
20's would be a nice addition, I don't know cutting the stock springs, but its all good!
Old Jun 1, 2006 | 09:42 AM
20tCDude05's Avatar
I am thinking going with these:
19" TSW Black Montages:
On a Super White tC:
Credits go to Jester28 for the white tC.
I would get 19s and go with H-Techs as I have read they are perfect and safe for 19s for no rubbing.
rvascion
Nov 12, 2020 03:23 AM
Mjdavis1994
Sep 21, 2015 04:42 AM
Btp907
Sep 15, 2015 02:54 AM
StxArOne
Scion xA Aero & Exterior
Aug 21, 2015 06:44 PM
Scionxa180
Jul 25, 2015 05:22 AM
