VSE Bazooka Airspace
Old May 29, 2006 | 07:54 PM
xtonyC's Avatar
Default VSE Bazooka Airspace
I was unable to find any information on the airspace for the Bazooka sub option. For those of us that are planning on upgrading the sub/amp, I did some estimated calculations.
These dimensions MAY or MAY NOT be exactly to par. I have done these based on LENGTH x WIDTH x HEIGHT of the box portion PLUS the LENGTH x WIDTH x HEIGHT of the triangular portion (the part of the box nearest the front of the car).
Based on my ROUGH calculations, I came up with 2,028 cu. in. = 1.17 cu. ft.
The subs I'm looking at, Alpine Type-S and Type-R, meet these specifications. I currently have the port sealed for the Bazooka sub, but the Type-R would have to be ported. So make sure you check those specs for ported/nonported.
Also, if anyone has ANYTHING to add to this, including your own calculations for airspace, PLEASE post them.
Old May 29, 2006 | 08:37 PM
Hudnut's Avatar
Let us know how the new driver / amp sounds. I have some new gear layin around that would fit in the VSE but I'm not sure if I want to put the effort into the install.
Old May 30, 2006 | 12:10 AM
xtonyC's Avatar
Will do. But chances are I'll be doing the same setup as the guy with the DIY Bazooka Upgrade thread, OR the next step up.
Here's the setup I'll most likely go with:
[Please critique and/or criticize]
    I think that should work. With that setup I'll have to unplug my port (I think). If this is incorrect, let me know.
    Old Jun 25, 2008 | 06:34 PM
    ippskidder's Avatar
    1UP Crew
    Nice airspace info.
    Old Jun 25, 2008 | 11:34 PM
    nodsetse's Avatar
    Search and you'll find lots of posts where people guesstimated the space, just as you did. Some of them figure it's actually closer to 0.75', which is considerably different than your estimate of 1.17'. Take the time & effort to measure it right, so you can be certain of the volume and get a sub that's optimal for it.
    All you need is cardboard, tape and some type of "filler" (sand, styrofoam peanuts, popcorn, etc.). Make a cardboard box that's exactly 12"x12"x12", which is precisely 1 cubic foot. Fill the sub enclosure completely with whatever filler material you decided to use for measuring. Pour all the filler material from the enclosure, into your 1' cardboard box. Now you should be able to easily determine the enclosure's internal volume, either by sight or by measuring. If the box is 75% full, then the enclosure is 0.75'. If the material is 10" deep in the cardboard box, then the enclosure is 0.83'
    Old Jun 26, 2008 | 03:51 AM
    xtonyC's Avatar
    Haha, check the date man...this thread is over 2 years old...I never ended up doing the setup but know many people that have, and it worked fine based on my specs.
    Old Jun 26, 2008 | 10:14 PM
    ippskidder's Avatar
    1UP Crew
    Do you know, with that upgraded setup you listed above, if its better to plug the port on the box, or better to leave it open?
    Old Jun 27, 2008 | 12:00 AM
    nodsetse's Avatar
    Aaaaarrrrrgggghhh! Thanks for pointing that out, as I didn't notice. Damn ippskidder making that post above mine, I wish people wouldn't post to such old, dead threads!
    toyotaisme
    Jan 10, 2015 10:24 PM
    JasonH
    Apr 14, 2010 04:01 PM
    iowagary
    Nov 17, 2004 02:39 PM
    bobbykokinos
    Oct 9, 2004 06:32 AM
    haze82
    Sep 5, 2004 02:26 AM
