Hard Wiring a Radar Detector
Old Jun 16, 2006 | 06:51 PM
SkyonXa's Avatar
Default Hard Wiring a Radar Detector
I need a fused source that's hot when ign on. I was looking around the fuse box but saw no extra terminals. Do I have to tap an existing wire? If so, which do you suggest?
Old Jun 16, 2006 | 07:23 PM
LEDMods_net's Avatar
Strictly Scionized
You could tap into the acc wire on the radio. It is already fused, but you could put your own in-line fuse if you like.
Or you could set up a relay if you are afraid of taking too much power from the radio (which a radar detector won't).
I forgot to mention, the accessory wire for the radio is gray. If you have an aftermarket radio, you could use the remote out wire (blue/white), or tap into the red accessory wire.
Old Jun 16, 2006 | 07:46 PM
TuningIsLife's Avatar
Or just take it off the cigarette light port.
Old Jun 16, 2006 | 07:55 PM
metal112524's Avatar
check the tech
Old Jun 16, 2006 | 08:06 PM
JohnnyStorm's Avatar
I just chopped the wires, grounded the negitive and put the positive wire in with the fuse. I comes on when I turn on car and cuts off just the same! Keep your cig lighter for your cell phone charger.
Old Jun 16, 2006 | 08:12 PM
Strictly Scionized
^^^ Which fuse are you tapping into?
You can use the cigarette lighter, I didn't suggest it because I don't remember if it is constantly on, or on accessory.
Old Jun 16, 2006 | 08:14 PM
Fujiz_xb's Avatar
sIcKsCiOnS
you can piggy back a fuse. YAAH better believe it.
Old Jun 17, 2006 | 02:16 AM
cjastacio's Avatar
There is a free fuse in the xB that I used. It's the upper right hand fuse. Not occupied by anything just ready to use and it turns on with acc.
Old Jun 21, 2006 | 02:16 AM
SkyonXa's Avatar
That's the way I finally did it. Shoved the wire in with the ACC fuse and grounded to the screw holding the fuse panel. Thanks for all the replies,
Old Jun 21, 2006 | 02:53 AM
saylor's Avatar
Default stab teh left side
stab the left side on the fuse block,,, the right side is the hot side,,, left side is the fused side...
I wrote a DIY on bringing a relay / 30A (300W) worth of power into the cabin - you only need a very small amount for teh detector...
https://www.scionlife.com/forums/vie...0a+power+cheap
don't cut any wires!!!
baby jesus cries every time someone cuts a stock wire!!!11
- Saylor
Zman
Apr 10, 2015 08:04 PM
mischman
Jan 14, 2015 06:07 PM
nhw
35
Jun 3, 2004 05:50 AM
bryanrx7
Jan 1, 2004 09:53 PM
