Having engine delay after installing intake
Old Jun 18, 2006 | 04:00 PM
TeeCizzle's Avatar
Default Having engine delay after installing intake
Waz Crack'in people..
After installing the intake I notice sometimes when I step on the gas theres a "delay" in the engine then POW! it takes off like a bat outta hell...Then sometimes it does it normal...
I have the short ram intake setup...becuz of this is there not "enough" air getting to the air filter???
or is cuz of the "drive-by-wire" system??
Thanks!!!!!
Old Jun 18, 2006 | 08:20 PM
JOEinSD's Avatar
we don't have a drive-by-wire system... or do we? LOL.
Old Jun 18, 2006 | 09:49 PM
2fast4you's Avatar
Team ScionTific
^^^ Yes, it is drive-by-wire.
Old Jun 18, 2006 | 10:11 PM
JOEinSD's Avatar
haha. im a
Old Jun 18, 2006 | 10:17 PM
zer0's Avatar
VVT-i
Old Jun 18, 2006 | 10:18 PM
wolfe's Avatar
I read on someone's CAI install thread that they let the car idle for 5-10 minutes after installing it, to let the sensor recalibrate itself.
No idea if that's necessary or if it'd help but might be worth a shot.
Old Jun 18, 2006 | 11:22 PM
JOEinSD's Avatar
i let mine idle for 5 mins. everything seems to be fine.
Old Jun 19, 2006 | 07:40 AM
Somnambulated's Avatar
On most cars, don't you have to disconnect the battery for 5 minutes or so to reset the ECU?
That way it can adapt to the intake?
Old Jun 19, 2006 | 08:24 AM
BuddhasTC's Avatar
the battery disconnection did nothing really, let it run a while, maybe drive it around the block, and check your owners manual because you're gonna probably have to reset the windows
Old Jun 19, 2006 | 02:09 PM
XD40tC's Avatar
Check your MAF sensor. Last time I cleaned my intake I put too much oil on the filter and it ended up getting all over my sensors and cause the same problem. Maybe your filter came pre-overoiled and youre having the same problem? Take a look at it and if it has oil clean it with some sensor spray.
hampton1100
May 28, 2015 07:32 AM
hotroddelux
Dec 3, 2014 11:33 PM
eric_m
79
Mar 17, 2013 12:21 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
eric_m
29
Oct 12, 2003 08:22 AM
