Under dash cold cathodes - $10 (pics!)
Old Jun 25, 2006 | 07:15 PM
SkuzzleButt's Avatar
Default Under dash cold cathodes - $10 (pics!)
I was in frys yesterday and saw a set of 2 12" cold cathode tubes that were made to run off of a computers 12v DC for only $10!
All you have to do is pop off the dash by removing the 2 screws under the A/C *****, then remove the oven by pulling it out. I drew power for the lights from the cigarette lighter, simply remember that the black wire is positive and the white is negative, if you mix these up you will fry the converter box.
Using a flat blade screw driver I popped out one of the blank accessory plates and used a dremel to cut out a slot to fit the switch in.
So in less than 30 minutes I had installed some lights just as good as the dealer does for 1/30th of the price!
These pics were taken around 2:00pm, so it may not seem very bright, but I'll post more pics when I get a chance to take them at night.
Also, please excuse the messy carpet.
Old Jun 25, 2006 | 07:29 PM
black_sand_box's Avatar
The Family
What is frys?
Old Jun 25, 2006 | 07:57 PM
mad-sciontist's Avatar
Scion Dynasty
I was wondering the same thing...
Old Jun 25, 2006 | 08:36 PM
sciondrgn's Avatar
Its a Computer electronics store..
You can get the cathodes for $6.97 a Pair through oznium.com
Im running 2 pair on mine
Old Jun 26, 2006 | 03:54 AM
mattross's Avatar
I'm running the same two pair from oznium as well. Great lights.
Old Jun 26, 2006 | 03:57 AM
davedavetC's Avatar
yup oznium for the win, im runnin 6 cathodes in my car (2 12" under dash, 2 4" inside console, and 2 12" in door panels) i love these thing
Old Jun 27, 2006 | 11:05 PM
The Family
Looks awesome @ night!
Old Jun 27, 2006 | 11:49 PM
TallGuy's Avatar
Default Re: Under dash cold cathodes - $10 (pics!)
Originally Posted by SkuzzleButt
... then remove the oven by pulling it out. I drew power for the lights from the cigarette lighter...
What is the oven? Did you wire it directly to the contacts in the lighter, or did u splice a wire or two?
Old Jun 27, 2006 | 11:56 PM
sciondrgn's Avatar
The oven is the small compartment right below teh Ac controls on the dash, its like a little oven,
You can splice into the power of the Cig Lighter and wire you up a switch.
Although what I did is wire it up to the Lights on the Automatic Shifter on the floor, Tie the power into those alogn with ground on one of the bolts and also wired a switch and when I cut my running lights on they will come on and they also flash when I arm/disarm my alarm
Old Jun 28, 2006 | 12:06 AM
Mazrim's Avatar
Phone cam, so take that in mind.
http://www.xoxide.com/meteorlightred.html
I pulled the control box out and spliced directly into the tube, this way whenever the power is cut off and resupplied it doesnt reset to flashing.
The vent was the same tube, I busted the tube open and ripped up the circuit board after the first 4 LEDs (they are in 3 chains of 4 each).
Old Jun 30, 2006 | 04:40 AM
mattross's Avatar
I have those floormats^^^^^
Old Jun 30, 2006 | 03:23 PM
surfcitylocal's Avatar
Be carfull, the cold cathode thing can get really addictive!
And I'm not done yet!
Old Jun 30, 2006 | 10:03 PM
BoughettiXB's Avatar
surfcitylocal? Do you have that rearview mirror that have the leds under it? It looks like you do from the pics? I just can't exactly tell. If you do how does it work exactly?
Thanks
Old Jul 1, 2006 | 12:44 AM
Thanks
It runs on AA batteries! Cool huh?
Old Jul 1, 2006 | 05:02 AM
So where is the switch exactly?
Old Jul 1, 2006 | 05:18 AM
raceronabudget's Avatar
hey i did some cathodes in my xb too, but the install isnt too clean. wondering how you guys mounted the tubes under the dash.
Old Jul 1, 2006 | 05:27 AM
Neothin's Avatar
zipties!
Old Jul 1, 2006 | 06:35 AM
The switch is on the lower left hand corner. The batteries are in a compartment on the front side of the mirror.
Old Jul 1, 2006 | 07:02 PM
Neat! Does it just clip onto the mirror? Does it look clean when on the mirror and all that? I might order one of those mirrors! Looks cool, bigger mirror, and easy to install! (NO WIRING! YAY)
Old Jul 2, 2006 | 07:15 AM
DiStUrBeD_AzN's Avatar
Unique Scionikz
I have a question on how to actually install these cathode lights. I would like to have a few in my car. xD
How do you turn them on and off? And how did you get all those cathode lights in there, surfcitylocal? I love it! I personally think you over did yourself but thats great, mind helping me out? =D
