Turbonetics concerns.... Any ideas??
Hey all. First off the kit is great so far but something started happening lately. Now I did hook up a boost controller but not sure if this might be contributing to it but when I hit boost and in full throttle, the car siezes and feels like it hits a brick wall. I lose all power and it stutters but never stalls. Kinda scary but it also makes a fluttering sound from the exhaust. Now I am running with no diverter valve(all atmosphered) but I don't think that can be it being that I barely am in boost when this happens. I checked all lines and clamps. Surprise, no boost leaks and everything seems fine. Oil pressure and EGT's are spot on and no check engine light either. I am getting it tuned Wednesday but wanna know if you guys have any ideas what might be wrong. Thanks
If you are venting the BOV to atmosphere that is most likely the cause. The tune on the Unichip was not tuned for an atmospheric vent. That definitely has to be tuned for even more so when the BOV is after the MAF as it is on this car...
Is the pre-tuned unichip rich anyways?? Cause even at full throttle my Wideband is pig-rich?? Been venting for sometime and now its doing this. Weird but I'll put the diverter back on for now and see whats up
Any word on what it was?
Do you have a CEL?
My CEL is on only due to the fact i no longer have any CATS on my car so i'm used to the light being on but i didn't check the codes for a while and when they checked the codes i was throwing a code that had to due with my MAF sensor. It just so happened it was a little dirty and reading wrong so it would seize like that around third gear around 5800rpm. After the cleaned it and erased the code i no longer had that problem.
Do you have a CEL?
i tried dumping to atmosphere too. At first things were fine and the sound is so much better then not dumping to atmosphere. I'd say about 5 miles later down the road, it experienced the symtoms you said, the symptoms of a too rich car.... i hooked it back up let it idle for a minute and things were back to normal. Weird how it didnt do this earlier
I have no CELs on the car at all. As for being atmospheric it runs damn rich but it sounds so awesome
We'll see this Monday. Dyno and turn boost up to 10psi. I'll post pics and hopefully vids
