Need some help - I messed something up!
Old Jul 11, 2006 | 02:22 PM
hammy's Avatar
Default Need some help - I messed something up!
Hey all,
I was fiddling with my LED lights that i took out a while ago. I wanted to put them in the cupholders now that i found my hot glue gun. (the ghetto rigged eletrical tape didnt hold them, thats why i took them out)
anyway..in the past i had connected them to the power supply for the shifter (? its a little blue box with 4 wires connected). THis is the same supply for your Speedometer light, dash lights. I checked the fuses and i dont believe any of them were blown. didnt appear that way anyway.
Somehow i messed it up and there is no speedometer light. realized this last nite when i was driving home on the interstate. i had to use my iPods back light to check my speed. pita.
I didnt mess with anything really. I put the soldered ends (2) of the leds into the openings for the other 4 wires. Just like i had done last time (no problems last time).
any ideas what i did?
no camera = no pics
thanks in advance.
-teo
Old Jul 11, 2006 | 02:52 PM
TuningIsLife's Avatar
This might sound really stupid, but I have seen it done. Did you check to make sure the Illumination switch was turned up? Then, do your A/C controls light up? They are on that circuit.
Old Jul 11, 2006 | 02:55 PM
hammy's Avatar
yeah, that was the first thing i checked.
the air conditioning works but the lights behind the console do not.
I didnt pull any wires out of anywhere - i only tried to sneak the LED wires into the same ports...worked last time no problem.
very dark ride home last nite.
thanks for tryin!
anybody else?
Old Jul 11, 2006 | 02:57 PM
Welp, time to find the blown illumination fuse. Recheck all of them, get a multimeter and make sure they have conductivity. Visual inspection doesn't always do it.
Old Jul 11, 2006 | 03:04 PM
hammy's Avatar
K.
thanks..i dont have the tools, but i know some folks who do.
I checked the fuses last nite and none looked blown - but like you said..looks can be deceiving.
I was worried that i accidentally disconnected something. but the wires seem to be snug still.
That blue housing with the 4 wires going in it is in an incredibly tight little place.
Old Jul 11, 2006 | 03:11 PM
I have a manual, so I don't know about shifter lights, but I do know that when I was putting LEDs in my A/C controls, I did blow a fuse.
Old Jul 11, 2006 | 03:43 PM
hammy's Avatar
ok man,
thanks for all your help...
it probably is a fuse..just didnt look that way..
i checked like 4-5 fuses cuz i wasnt exactly sure which one...
Old Jul 12, 2006 | 12:30 PM
hammy's Avatar
Does anyone know which Fuse controls the speedometer light and Console Lights (AC/Radio button backlights)
I picked up some 15A fuses and replaced the ACC fuse..but thats apparently not the right fuse to replace or not my problem..
I cant see how fast im going at nite! I need some help pronto!
Thanks again
Old Jul 12, 2006 | 02:22 PM
hammy's Avatar
actually - i cant see how 'slow' im going at nite.
Old Mar 26, 2007 | 02:53 AM
DrBlast33's Avatar
Did anyone figure out which fuse? I have same problem.
Old Mar 26, 2007 | 04:40 AM
mom2boysdadsxb's Avatar
That would be the 10A TAIL fuse.Looking at under dash fuse block it is top row far right.BTW your running lights aren't working either.
Old Mar 26, 2007 | 08:42 PM
DrBlast33's Avatar
Yup, TAIL was the fuse... but it keeps blowing... I have a feeling, Im going to have a heck of a time finding the problem!
Old Mar 27, 2007 | 12:55 PM
DO you have ANYTHING drawing on the parkinglight/ headlights?
Old Mar 27, 2007 | 01:56 PM
oldmanatee's Avatar
I had the same problem, cup holder LEDs were shorting out the speedo/tail light fuse, for me, it turned out to be a simple short in my wiring...re-check all the wires you used for your cupholders, I bet there is a pinched wire....
Good luck!
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
sabot7726
Apr 28, 2016 08:20 AM
Sgtfluffy16
Sep 30, 2015 01:42 PM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
blackpearlTC
Jul 19, 2015 04:55 PM
