Need some help on a wheel setup
Old Jul 13, 2006 | 12:33 AM
06PolarWhitexB's Avatar
Default Need some help on a wheel setup
Does anyone know what size these wheels and tires are and if they are running any kind of spacers or anything? I mean width and everything. Thanks guys
Old Jul 13, 2006 | 02:15 AM
nokia6230exp's Avatar
hey. the size of those should be 18x8.5 in the front and 18x9.5 in the rear. thats the set up i use on my PW xb with Sportmax 006.. u'll have to run OTG spacers (10mm) and a spacer shim(5mm) as for the tires... fronts would be 215/35/18 and rear - 225/35/18.. u'll get about a stretch look on those tires.. BEWARE though with this wheel set up.. if ur lowered ( im lowered 2") you'll rub.. i had to roll my fenders.. these wheels take a lil time and patients to get running right..
thats the same size setup as those 962
Old Jul 13, 2006 | 02:28 AM
so i'll need a 10mm spacer for the rear and 5mm for hte front? it just looks like bbist's setup sticks out a bit more than your's maybe it's just an illusion to me. lol
Old Jul 13, 2006 | 02:41 AM
hotbox05's Avatar
you should pm bbist . he's on this site , sells those wheels and will be more than happy to teach you/sell you things. he's a great guy. his name is steve
Old Jul 13, 2006 | 02:54 AM
you'll need a OTG 10mm rear spacer with a 5mm spacer shim.. so the rear has a total of 15mm spaced out.. i think the bbist one has a total of 20mm spaced out thats why it sticks out more
Old Jul 14, 2006 | 01:48 AM
so does the bbist one also have a spacer on the front as well or no? i've pm'd him and I'm still waiting on his response. sorry for all the questions guys.
Old Jul 14, 2006 | 02:00 AM
no problem man..here to help.. the bbist one.. i not sure if he's running a spacer in the front.. he might though
Old Jul 14, 2006 | 10:19 PM
KenzokuXB's Avatar
I'm guessing he does since he is running the fender flares.
Old Jul 14, 2006 | 10:22 PM
hotbox05's Avatar
those fender flares are non functional. the metal fender is still underneath. youy can';t run your tires to go into the fender flares theyre just stuck on. he might have cut the fenders underneath but i don't believe he did. 99% of people do not.
Old Jul 17, 2006 | 01:45 AM
So if I run no spacers on the front and 15mm worth of spacers in the back, my setup will look similar to Nokia6230's setup? Also I've been told I should get extended lugs for the back since I'm using spacers just to be safe. Is this required or would it be a good recommendation to do this?
That_Kid_Ju
Jun 26, 2015 10:57 PM
my06tc
Jun 25, 2015 12:18 AM
Beesh
Jan 9, 2015 06:30 PM
ft86chick
Scion FR-S ICE & Interior
Jan 8, 2015 05:59 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
