mounting amp on sub enclosure
Old Jul 14, 2006 | 05:55 AM
tc182's Avatar
Default mounting amp on sub enclosure
is it a bad idea to mount an amp on the sub box? will it effect or damage anything in anyway? if its safe to do, are there certain things i should take into consideration?
Old Jul 14, 2006 | 02:03 PM
SCI_TC_GUY's Avatar
Alot of people have their amps mounted to the enclosure. Some people say the vibrations of the sub/enclosure could damage the internal components of the amp, but if your enclosure is solid and braced, I don't see that happening.
Old Jul 14, 2006 | 04:06 PM
CletusTC's Avatar
Mounting the amp to the sub box is ok as long as you're smart enough to bolt the enclosure down securely. Otherwise, your neighborhood theif (AKA, douchebags) will have no problem getting all your poop with one easy snip of the wirecutters
Old Jul 14, 2006 | 08:17 PM
FaulknerScion's Avatar
abou thte vibration... i would try rubber mounts between the buts and bolts... and then securing it tightly.
Old Jul 14, 2006 | 08:19 PM
CletusTC's Avatar
between the buts??
Old Jul 14, 2006 | 08:22 PM
well... make it... bolt:washer:rubber washer:amp:
so a washer can hold the rubber washer... and then the rubber can hold the amp... so it's not chattering on the metal one.. and so it absorbs some vibration.. instead of it going directly to the amp.
SoCal_CJ
Jan 27, 2023 05:42 PM
Hydryman
Feb 23, 2016 03:35 PM
crimson10tC
Sep 10, 2015 08:44 PM
javio24
Aug 23, 2015 01:07 AM
DJrepresent
Aug 12, 2015 06:37 PM
