how did u guys mount your tweeters in the stock location?
Old Jul 26, 2006 | 06:48 AM
05FMtC's Avatar
Default how did u guys mount your tweeters in the stock location?
so i removed the door panel with ease but when i looked at the tweeter i was confused as how i would mount the new tweeters in the stock location. it seems like the stock ones are mounted via a metal bracket, is there a way to reuse this, w/o having to damage the stock tweeter in the removal process? thanks.
Old Jul 26, 2006 | 02:41 PM
ndnbolla's Avatar
I am on the verge of installing new tweeters myself.
I thought about this too and have decided that instead of using the metal bracket, I am going to just drill the mount that came with the tweeter directly onto the door which means I will have to do some drilling.
Old Jul 26, 2006 | 02:56 PM
NoLimitzBuilt's Avatar
Team No Limitz
I used the mount. I bent it around a little and drilled a hole through the center. That way I could mount the tweeter to the factory baracket and still be able to angle it a little. It worked out really good.
Old Jul 26, 2006 | 07:13 PM
RJonesy's Avatar
05FMtC, I used the stock mount like NoLimitzInc said. Just drill a hole through the middle and you will be fine. You and Me need to hang out, I'll help you out finishing your install and you can help me with my amp rack and trunk floor.
Old Jul 26, 2006 | 07:59 PM
mandos's Avatar
Step one, rip off stock tweeter
Step two, get 3m super adhesive double sided tape
Step three, attach new tweeter to stock mount
Step four, reattach tweeter mount if you ripped it off.
Old Jul 26, 2006 | 08:40 PM
05FMtC's Avatar
yeah rhett just let me know when. im usually free during the ends of the weeks.
Old Jul 26, 2006 | 08:41 PM
Team No Limitz
LMAO at Chris.... "Reattach if you ripped it off"... That is so true half the time..
Old Jul 27, 2006 | 01:15 AM
deathbyc4's Avatar
i cut a piece of wood the same width, depth, and height as the part of the bracket where the oem tweeter goes. then i drilled a hole through it so i could secure it through the notches in the stock bracket. then i 3M taped my tweeter to it. now the tweeter is close to the tweeter hole so you can see it.
Old Jul 27, 2006 | 02:19 AM
05FMtC's Avatar
yea i ended up doing half of the install today, and all i gotta say is DAMN those things are loud. i got jl xr 650 comps. just having one in makes the other sound like its not even on. and for the tweeter, i used the hole that the bracket was attached to the door with. the tweeter is not in the spot where its susposed to be but i really dont care b/c i hate harsh tweeters anyways. thanks for all of you help guys.
Old Jul 27, 2006 | 02:45 AM
jwaggz82's Avatar
mounted mine w/ the stock mounts:
Old Jul 27, 2006 | 04:47 AM
Makaveli's Avatar
i mounted mine with heavy duty mounting foam. its works well and easy to take off.
Old Jul 29, 2006 | 09:23 AM
05FMtC's Avatar
the difference if like WOAH with comps. i love them, now i can actually hear the words over my sub. cant wait to do the rears.
lunchbx05
Dec 29, 2014 07:53 PM
darkshadowofxdeath
Dec 3, 2014 06:59 PM
DjFrOsT
Dec 13, 2003 04:18 AM
