tein S techs
Old Jul 27, 2006 | 10:15 PM
bombdigity510's Avatar
Default tein S techs
hey i was just wondering about the tein s tech springs....it says it drop 2.4 inches in the front and i was wondering is there any rubbing of the tires and is it hard to get over speed bumps?
Old Jul 28, 2006 | 12:31 AM
BuddhasTC's Avatar
rubbing on 19's from what i hear, and minor rubbing with 18's ony when it's turned all the way to one direction
Old Aug 1, 2006 | 04:08 PM
Borisimo's Avatar
It also depends on how much weight you have in your car. You might be fine one day, and then decide to give 4 of your friends a ride and will rub.
Old Aug 4, 2006 | 01:13 AM
texasisbigger's Avatar
Do not listen to this guy.
I have 19x8's and S-Techs and I only rub on the left inner fender when I take corners EXTREMELY hard. I did lots of research before purchasing and that seems to be common with most on 19's. I also have no issues with rubbing during full-lock (left or right) turns
Don't let that scare you though, I drive fairly aggresively and I only rub once to twice per month.
I have NEVER heard of anyone rubbing with 18's with a reasonable offset/width. Obviously if you run a crazy offset or 9+ inch wheels, you need may need to do some trimming
If you like the low look, like I do, get the S-Techs. If you want a bit more comfort, go with the HR's.
Hope it helps-BrianH
Old Aug 4, 2006 | 05:10 PM
NoLimitzBuilt's Avatar
Team No Limitz
I had S techs and 20's no rubbing. I have a ton of weight in the car and have 4 people in the car also. It is all in your offset of the wheels.
Old Aug 4, 2006 | 09:14 PM
tc2nut4's Avatar
what offset would you go with no limitz
Old Aug 4, 2006 | 09:36 PM
losmorob's Avatar
I'm running 15's (not stock) but with orig tires. No rubbing at all in 12,000 miles with a variety of weight, conditions.
Speed bumps are not a problem when taken SLOWLY.
Treat it like any other lowered car.
Add a set of Koni Sportline shocks set to 1/2 turn from max soft in the rear for a great improvement in ride.
Old Aug 4, 2006 | 09:39 PM
losmorob's Avatar
[quote="texasisbigger"]
I agree. the look can't be beat. And handling is improved.
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
jnesselroad
Sep 15, 2015 06:57 AM
