tein S techs
rubbing on 19's from what i hear, and minor rubbing with 18's ony when it's turned all the way to one direction
I have 19x8's and S-Techs and I only rub on the left inner fender when I take corners EXTREMELY hard. I did lots of research before purchasing and that seems to be common with most on 19's. I also have no issues with rubbing during full-lock (left or right) turns
Don't let that scare you though, I drive fairly aggresively and I only rub once to twice per month.
I have NEVER heard of anyone rubbing with 18's with a reasonable offset/width. Obviously if you run a crazy offset or 9+ inch wheels, you need may need to do some trimming
If you like the low look, like I do, get the S-Techs. If you want a bit more comfort, go with the HR's.
Hope it helps-BrianH
I'm running 15's (not stock) but with orig tires. No rubbing at all in 12,000 miles with a variety of weight, conditions.
Speed bumps are not a problem when taken SLOWLY.
Treat it like any other lowered car.
Add a set of Koni Sportline shocks set to 1/2 turn from max soft in the rear for a great improvement in ride.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
