HELP HOW TO DETAILED CAR
Old Jul 29, 2006 | 06:11 AM
polonyc1018's Avatar
Default HELP HOW TO DETAILED CAR
fellas i need help to detailed mah scion xb. need to know step by step. i heard meguir
is the best out their right now.. help pls
Old Jul 29, 2006 | 07:58 AM
blue_06tC's Avatar
-Wash it buy hand. Never take it through an automatic car wash. Some of the junk from the car before you can get caught in the shammies and mess up your vehicle.
-Invest in some soft microfiber towels for washing,buffing and waffle weave microfiber towels for drying. Use a quick detailer solution as a lubricant when drying to help reduce drag on the paint.
-Use two buckets for washing. Use one for clean water and one for dirty water. Rinse your towel after each panel,this will help reduce marring/swirling.
-Using a clay bar helps remove a lot of the junk inbedded in your paint. Even new cars need this sometimes.
-If you have swirls or anything of the like, the only way to really get rid of them is by machine polishing. I have found that is next to impossible to do any kind of paint correction efficiently by hand.
-Choose a quality paint protectant. If you want something that gives more depth and a deeper color,go with a carnauba wax like Poorboys Natty's/Natty's Blue or Pinnacle Souveran. If you want something that gives a sharper,more reflective and more true to color,go with a polymer sealant like those from Zaino. The sealant will generally last a lot longer than the carnauba,but I have found that the carnauba protects better than a sealant.
Check out these sites for more info:
http://www.autopia.org
http://www.detailcity.org
Old Jul 30, 2006 | 04:41 PM
denny2217's Avatar
All the help you will ever need is in at this place!!
www.meguiarsonline.com
anything and everything you can find on there. lots of people to help you out.
Old Jul 31, 2006 | 01:07 AM
lil_blue_star's Avatar
Very nice tips for washing. Here's another for you. Clean the inside of the car first, vacuum and windex and all that. I avoid Armorall/anything shiney product on my dash. Eventually that stuff will dry out your dash and it'll crack. Also, it makes the surface 'sticky' and you see everything dust wise. I use a drying towel, can't spell it but a chamey or lambskin sheet, and wipe it over the dash and door panels.
I've heard about using ATF on your tires over a period helps them last longer and makes them shine without dealing with spinnoff from other products. I don't know if this is true and I haven't tried it out yet.
Beesh
Jan 9, 2015 06:30 PM
TheTripleC
Jan 4, 2015 06:46 PM
carid
Nov 21, 2014 11:00 AM
ScionLife Editor
Nov 20, 2014 05:20 PM
tC_Normo
Oct 22, 2003 07:20 PM
