Keyless Entry Problem !!!!!!
Old Aug 1, 2006 | 05:08 PM
BlueTC06's Avatar
Default Keyless Entry Problem !!!!!!
I recently installed a subwoofer and amp to my car. I spliched the wrong gray wire in the back rear side of the car for a remote turn on. I realized after I hooked up the amp that it was not turning off. So I connect the wires back and took out the radio and did it that way. The first gray wire i nthe back is now too short for me to hook back together so I added a wire but I only had a larger gauge so i don't know if thats my problem. I check the wires behind the radio and everything was fine. Now I did'nt have this problem (keyless entry not working) when I had it hooked up in the back. I unhooked the battery to reset the ecu (did not work) and check the fuses and those failed so I took it to the dealership and they said that theres a chance I voided my warranty by doing this. I'm trying to fix it without going there. Has any one had this problem? or Does anyone know how to fix it ?
Old Aug 1, 2006 | 05:25 PM
blk06_tc's Avatar
you didnt add the wire right get a but connector
Old Aug 1, 2006 | 06:00 PM
BlueTC06's Avatar
what do you mean but connector ? I used the twist nut style connectors
EcoxA
Mar 28, 2015 06:28 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
Kiwibox
Dec 15, 2014 09:46 PM
randomsuper
Dec 15, 2014 08:29 AM
