safc2 or e manage w/ECU
Old Aug 2, 2006 | 11:00 PM
Ex_sPEC's Avatar
Default safc2 or e manage w/ECU
anyone know if the ECU relearns itself and u would have to tune ur car again.(people with turbo).....did some research and found out that most of the newer car have a ECU that over time it would go back to stock setting.
Old Aug 2, 2006 | 11:34 PM
3min3m2's Avatar
i have heard"not experienced myself" that there is a way to go around the ECU relearning.....i tihnk its Charles that did it? not entirely sure, but i tihnk someone has done it.....
Old Aug 3, 2006 | 03:10 AM
Ex_sPEC's Avatar
anyone??????
Old Aug 3, 2006 | 02:26 PM
rhythmnsmoke's Avatar
Music City Scions
The E-manage works just fine with the stock ECU.. Been running it for quite some time now.
Old Aug 3, 2006 | 07:58 PM
Joe_Dezod's Avatar
Either one will work fine with our ECU but...
The stock ECU is relearning. There is no way around that part. Anything below 80% throttle the ECU will control. There are almost zero devices out there that can control that part.
Between the Emanage and SAFC... Go with the Emanage. The SAFC is definately easier to tune for fuel, because you dont need a computer or E01 boost controller, but it's more simple. You can't change your fuel tune with different boost levels, you need to always re-tune the entire thing. It also won't do ignition timing, which is a MUST for anything over 8psi if you want your motor to last. The Emanage is definately a bit more complicated but has more features. You can tune fuel and ignition, and use signals such as TPS, MAF, and MAP. It's a very powerful unit if you do it right.
We're still working on our new EMS but have made some recent HUGE developments. So in the meantime, play it safe and go for an Emanage.
Old Aug 3, 2006 | 09:59 PM
Simplyscion's Avatar
Team No Limitz
yea, id definitely go with the emanage over the S-AFC II...its a half a$$ way of tuning if you ask me, plus I think it can only plot 16 tuneable fuel points...8 low and 8 high.
Old Aug 5, 2006 | 04:26 PM
deathbyc4's Avatar
Hey Joe, have you done a TRD reflash and the e-manage together? I talked to my local dealer about doing the reflash and they said they would and I will still be using my SAFC-II for the extra fuel.
Old Aug 6, 2006 | 07:19 PM
JustAtC's Avatar
typical dealer's responses. I guess technicallly is possible but who has the time and knowledge to do the whole thing.
Old Aug 6, 2006 | 07:39 PM
Team No Limitz
its definitely possible...why wouldnt it...I am using the TRD reflash and a Unichip to clean up the A/F ratios and also to bump timing with my Spearco Water/Meth injection kit. The reflash is just an ECU burn obviously and the piggyback will just be altering the reflash map.
Old Aug 6, 2006 | 09:34 PM
deathbyc4's Avatar
yea i'm just a little worried for when i do it, since the dealer is about 20ish miles from the dyno. not sure if i could retune the safc at the dealer to compensate the change. any ideas on that?
Old Aug 7, 2006 | 04:25 AM
Team No Limitz
I dunno, I think if your going straight to the dyno from the dealer you should be alright...the reflash is super rich so if your worried about it leaning out it shouldnt be an issue. I got a good idea, just dont shift past like 4000RPMs cause doesnt the S AFC only control the fuel points after that anyway? Plus you will only hit about 1 psi at that rpm range if you are using the stock diverter valve
yupinmytC
22
Jul 27, 2024 07:08 PM
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
sccarally
Regional - Lonestar
Sep 27, 2015 09:24 PM
paisatronix
Sep 5, 2015 04:13 AM
