safc2 or e manage w/ECU
anyone know if the ECU relearns itself and u would have to tune ur car again.(people with turbo).....did some research and found out that most of the newer car have a ECU that over time it would go back to stock setting.
i have heard"not experienced myself" that there is a way to go around the ECU relearning.....i tihnk its Charles that did it? not entirely sure, but i tihnk someone has done it.....
Either one will work fine with our ECU but...
The stock ECU is relearning. There is no way around that part. Anything below 80% throttle the ECU will control. There are almost zero devices out there that can control that part.
Between the Emanage and SAFC... Go with the Emanage. The SAFC is definately easier to tune for fuel, because you dont need a computer or E01 boost controller, but it's more simple. You can't change your fuel tune with different boost levels, you need to always re-tune the entire thing. It also won't do ignition timing, which is a MUST for anything over 8psi if you want your motor to last. The Emanage is definately a bit more complicated but has more features. You can tune fuel and ignition, and use signals such as TPS, MAF, and MAP. It's a very powerful unit if you do it right.
We're still working on our new EMS but have made some recent HUGE developments. So in the meantime, play it safe and go for an Emanage.
Team No Limitz
yea, id definitely go with the emanage over the S-AFC II...its a half a$$ way of tuning if you ask me, plus I think it can only plot 16 tuneable fuel points...8 low and 8 high.
Team No Limitz
its definitely possible...why wouldnt it...I am using the TRD reflash and a Unichip to clean up the A/F ratios and also to bump timing with my Spearco Water/Meth injection kit. The reflash is just an ECU burn obviously and the piggyback will just be altering the reflash map.
Team No Limitz
I dunno, I think if your going straight to the dyno from the dealer you should be alright...the reflash is super rich so if your worried about it leaning out it shouldnt be an issue. I got a good idea, just dont shift past like 4000RPMs cause doesnt the S AFC only control the fuel points after that anyway? Plus you will only hit about 1 psi at that rpm range if you are using the stock diverter valve
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
