INJEN CAI making my car bog?
Old Aug 4, 2006 | 08:37 PM
1ahBSP's Avatar
Default INJEN CAI making my car bog?
Hey guys I installed INJEN's cai a few weeks ago and obviously my car felt a little differnet as the ecu played around with the new intake. Basically im wondering if this is out of the ordinary. When I first start my car and try to accelerate like within 5 seconds of starting the car it doesnt get enough fuel and bogs like its going to die but doesn tcompletely die. Then after a little its fine. Is this normal just because the air//fuels a little bit off? Does it effect my car at high RPMs and higher gears while racing etc am i not gonna get enough fuel. Thanks in advance
Old Aug 4, 2006 | 09:09 PM
dp-_-'s Avatar
when you turn it on it is kinda like the car farts and dies...then you have to try to turn it on again....is that what you mean?
Old Aug 4, 2006 | 10:15 PM
1ahBSP's Avatar
like my cars parked
i turn the ignition
then pop it into reverse and hit the gas a litlte
rpms drop and i feel liek its about to die then give it a little more gas and its all good...
Old Aug 4, 2006 | 10:36 PM
HP_Pirate's Avatar
Do you have exhaust?
Old Aug 4, 2006 | 10:50 PM
1ahBSP's Avatar
yes Injen's axle-back
Old Aug 4, 2006 | 11:06 PM
tc2nut4's Avatar
hmm interesting... i would think our ecu could compensate for this... ::watching::
Old Aug 4, 2006 | 11:39 PM
dp-_-'s Avatar
here's a question...did you reset the ecu?
Old Aug 5, 2006 | 12:17 AM
senseiturtle's Avatar
Resetting the ECU isn't necessary... In fact, it seems to make me slower.
If it's idling, then its fine. Idling is actually a very hard thing for a motor to accomplish, as it takes a good bit of tuning. You might just have to give it extra gas when reversing, could be low-end tq loss or could be placebo
Old Aug 5, 2006 | 05:46 AM
3min3m2's Avatar
i reset my ECU after adding exhaust to my intake, and i gained several hp(feeling, not dyno), so that is a possibility
Old Aug 5, 2006 | 06:44 AM
HP_Pirate's Avatar
These cars have what we call Idle learn.
You need to reset the ECU anytime you change something and let it run for 15 min. at Idle without touching the car.
minter66
Dec 15, 2014 01:45 PM
ScionLife Editor
Nov 20, 2014 05:20 PM
eric_m
29
Oct 12, 2003 08:22 AM
EV_AIC-xB
11
Oct 10, 2003 07:28 AM
2fixA
Sep 25, 2003 08:06 PM
