CAI Bracket
Old Aug 10, 2006 | 05:43 AM
boomshakadae's Avatar
Default CAI Bracket
Help Anybody else have the bracket holding their CAI snap!?!
Better photo in the morn
Old Aug 10, 2006 | 05:45 AM
raytrix's Avatar
yup you arent the only one... im actually runnin it with NO bracket.. its fine for now..
Old Aug 10, 2006 | 04:04 PM
engifineer's Avatar
K&N? Of course.. I warn everyone of that. You are one of the many I have heard of with this issue other than myself. Worst mounting design ever. I took the one I was given off after it broke mine. It will begin rattling like crazy after a while too. Considering mine was free.. and the CAI is 99.999% looks and sound.. its not a biggie to me.. but it really is a crappy design
Old Aug 10, 2006 | 05:44 PM
it's actually a injen, dealer installed. wellknowing i'm not the only one doesn't make me feel better. metal snapping like that lowers my confidence the the build quality of the car, i mean the cai isn't THAT heavy. i wonder if a engine damper could have prevent this...
Old Aug 10, 2006 | 05:48 PM
engifineer's Avatar
I have heard of a couple of injens doing that.
It has absolutely nothing to do with the quality of the car, it has to do with the quality of the intakes. That bracket is meant to hold the stock airbox, which has two other bolts securing it so it does not move. It is not the weight of the CAI, it is the fact that it moves when the engine torques, and the "smart" people that designed the mounting made it bolt to a piece that is not supposed to move. The stock mounting point would never break with the stock airbox, it is the poor design of the CAI's that cause it to break. An engine damper will help some since you reduce engine movement.. but personally if I ever put mine back on I will design a proper mount point. There are a lot of solid places to mount from. Then you just make a flex mount that will not put undo stress on everything
Old Aug 10, 2006 | 06:00 PM
tc2nut4's Avatar
^^^ I got a design made up for mine maybe i'll upload pics in a bit...
Old Aug 10, 2006 | 06:07 PM
engifineer's Avatar
I was thinking of a flat plate with bolt holes that would connect it to the two mounting points on the feder. It would stick out enough for the CAI moutning point. Then, it would use a very soft rubber busing to mount the CAI to it. This should work a million times better than that original. What did you have in mind?
yupinmytC
22
Jul 27, 2024 07:08 PM
yhwhdesign
Jun 11, 2021 03:34 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Chrono
Aug 25, 2015 05:59 PM
