LEAN WIT IT? HELP!
Old Aug 15, 2006 | 03:36 PM
jdmbb06's Avatar
Default LEAN WIT IT? HELP!
Hi im new to this site and just got my 06 bread box. I hate the way you lean in high speed turns, my question is what parts do i need to fix this.someone help, im tired of 3 wheelin in turns, almost tipped over my box.
Old Aug 15, 2006 | 04:37 PM
mattxb's Avatar
You can search sway bars, tower brace, etc..... good luck man.
Old Aug 15, 2006 | 04:46 PM
jdmbb06's Avatar
do you advise df210 or tien s tech for more handling
Old Aug 15, 2006 | 05:02 PM
joshsbox's Avatar
Springs are a good start. Biggest gains will be made by adding a rear sway bar, like Progress, and swapping out your front sway bar end link bushings to polyurethane.
Old Aug 15, 2006 | 06:28 PM
jdmbb06's Avatar
what about the camber parts for these springs iam leaning more to the df210s.
Old Aug 15, 2006 | 10:46 PM
BrianxB's Avatar
If you want ZERO body roll, run my setup.
D2 coilovers
DC front strut tower brace
Whiteline rear sway bar
Energy suspension poly bushings on front sway bar
One Ton Garage Camber plates - rear
Youll be good to go.
Old Aug 16, 2006 | 01:19 AM
evosky's Avatar
frame brace will help too. Cusco, GTSpec, APR, and Tanabe are big choices for those.
oh and wider wheels and stickier tires will help A LOT. it all starts at the tire.
if you are tricycling it through corners, you are going way too fast on public roads buddy. either that or the civil engineers decided to mess with drivers.
Old Aug 16, 2006 | 07:49 AM
jdmbb06's Avatar
whats the diiference in size between stock and after market sway bars(front)?
Old Aug 16, 2006 | 08:05 AM
OldYeller's Avatar
I noticed a big improvement in my cornering after installing Tein S springs and a Hotchkis front strut bar. As I installed both at the same time I am not sure which did the most good.
Old Aug 16, 2006 | 05:46 PM
jdmbb06's Avatar
THANX GUYS WHAT DO YOU GUYS THINK ABOUT REAR UPPER AND LOWER STRUT/TIE BARS?
Old Aug 18, 2006 | 03:17 PM
jdmbb06's Avatar
damn what a difference! just installed energy suspension endlinks and bushings. im very satisfied with the change.
Old Aug 18, 2006 | 10:07 PM
implayaz9's Avatar
i need to know more about this too
Old Aug 19, 2006 | 03:06 AM
bryman31's Avatar
just curious, whats the part #'s for the endlinks and bushings were they for front or back??
Old Aug 19, 2006 | 04:45 PM
TJ's Avatar
TJ
Go to this link https://www.scionlife.com/forums/viewtopic.php?t=78651 for all the information about the energy suspension end link bushings for the front.
Old Aug 19, 2006 | 10:41 PM
jdmbb06's Avatar
I got my fornt r=end link bushing kit from www.summitracing.com
part # ENS-9-8122R
Old Aug 19, 2006 | 11:47 PM
implayaz9's Avatar
hey BrianxB .. does it matter what coilovers u run? i mean what if i go with some teins or hks?
Praetoriate
Scion tC 2G Forced Induction
Jun 21, 2017 12:58 PM
Gigs
Sep 15, 2015 03:54 AM
mw1957
Jul 28, 2015 06:04 AM
mw1957
Jul 28, 2015 05:31 AM
my06tc
10
Jul 13, 2015 04:13 PM
