Question...
Old Sep 20, 2006 | 12:57 AM
DelayedTurbo's Avatar
Default Question...
Alright my friend is gonna give me his eclipses stock turbo and intercooler, my question is, what manifold if any would I be able to use? and I am really at like a crosroads of what to do, I know its a small turbo, and I don't really wanna do any engine work, so couldn't I run it at 6-8 psi with no issues?
Old Sep 20, 2006 | 12:59 AM
ProshopXB's Avatar
What turbo is it? model #
Old Sep 20, 2006 | 01:02 AM
Joe_Dezod's Avatar
The turbo can work but it will take some work to get it done. The T25 turbo does not flow that well so when the RPMs go up it may start tapering off, due to our larger than 2.0L displacement.
The internal wastegates on those turbos are set as 12psi so I'd weld that shut and switch to an externally gated setup. ZPI I believe can get you a T25 flanged turbo. We use the T3 flange.
As for your intercooler... The DSM intercooler is a plastic sidemount and will not really work on the tC. I'd upgrade to at least a cheap one from ebay if you're looking to do something cheap.
On a budget it could work, but only on a budget. There are much more powerful turbo kits out there from different suppliers on these boards, including our own. If you decide to go with the T25 turbo, check thoroughly for any shaft play and check the bearings. Those things start really wearing out after 50k miles.
Old Sep 20, 2006 | 01:03 AM
Joe_Dezod's Avatar
I guess I was assuming it was from a 95-99 Eclipse/Talon.
If it's an older eclipse, it's a 14b. Both will flow about the same, but the 14b will flow a little bit more.
Old Sep 20, 2006 | 01:10 AM
Its from a 97 GST Spyder, sorry I was lacking info, I'm kinda lacking info as well, lol. I am working on an extremely tight budget, I would love to get one of the kits that is offered but I would never be able to afford it. lol
Old Sep 20, 2006 | 01:13 AM
Joe_Dezod's Avatar
Well then I'll leave my first post the way it is lol. You will be spending more money on getting the turbo welded shut, and buying a new wastegate, but that's less than paying to replace your motor down the road from running no less than 12psi all the time...
I would honestly consider a better flowing turbo from ebay or something, along with the IC. You'd have a better performance, and probably spend about the same amount. Plus there will likely be less miles on it.
Old Sep 20, 2006 | 01:16 AM
ZPIracing's Avatar
This turbo will bolt to our manifold and downpipe. I would suggest a larger turbo we offer some inexpensive alternatives if you would like.. Doing a limited budget build of this nature on a new car is risky business. I would suggest nitrous or a more budget minded approch that will yield you safer results.
Old Sep 20, 2006 | 01:21 AM
Damn I was all giddy with excitement, sounds like turboing is just to expensive for me, lol...
Old Sep 20, 2006 | 01:37 AM
ProshopXB's Avatar
Well you can always be patient... save your money up to buy the best kit on the market and show all of NJ what ZPI power is all about...
toronado
Oct 20, 2016 03:42 AM
Unicron
Jul 25, 2006 06:40 AM
NYXbScion
Oct 18, 2005 04:02 PM
vanberge
Oct 6, 2005 03:11 AM
Docsnuff
10
Dec 30, 2003 07:23 PM
