does s/c lower mpg?
Old Jul 20, 2004 | 03:28 PM
iy0ga's Avatar
Default does s/c lower mpg?
just wonderign if the s/c will lower the mpg even with a intake? and how far wil it lower it.
Old Jul 20, 2004 | 03:40 PM
Reno's Avatar
most likely you will lose some MPG because you will probably drive it harder than you would have without the s/c
Old Jul 20, 2004 | 05:26 PM
KaPGuN's Avatar
I'm also assuming you have to switch to premium, right?
Old Jul 20, 2004 | 05:40 PM
Shadow_tC's Avatar
I always thought that you would lose MPG because you're adding more power, which in turn makes the engine work more. Am I wrong?
- Desi
Old Jul 20, 2004 | 07:22 PM
hawkeye's Avatar
- Desi
Yes. The engine is not necessarily working "harder." The supercharger adds more air in the engine which must have a corresponding amount more fuel.
If the TRD supercharger for the TC is like the one for the celica and adds an injector, then you will loose gas mileage b/c you add more fuel to the added air from the supercharger.
Old Jul 20, 2004 | 07:23 PM
JSVH's Avatar
Here is my logic on it:
the S/C gives you more power. More power makes you go faster. More power also uses more gas. BUT, if you add the super charger and dont use its added power (i.e. don't step on the gas pedal as hard) you should not use as much gas.
In everyday use it will probably hurt MPG by a few notches because it will be hard not to use that extra power some of the time. And if you add the S/C and dont use its extra power then why did you buy it in the first place?
Old Jul 20, 2004 | 07:27 PM
zoltiz's Avatar
N.G.S.O.
If anyone cares for the Rolla/Matrix SC experience:
Before the SC I was getting 26-28mpg running on 87 gas.
With SC I was anywhere between 24 and 30 mpg on 93 gas. It's all in your foot.
Old Jul 20, 2004 | 07:49 PM
KaPGuN's Avatar
- Desi
hawkeye is correct, a SC forces more air in, and in order to maintain the same AFR, a corresponding amount of fuel is also added. So at any particular engine speed, you will be using more fuel with a SC then that of an engine without... You will also be making more hp at that engine speed then the engine without SC.
Old Jul 21, 2004 | 02:28 PM
iy0ga's Avatar
will a intake help boost the mpg though
k1114
43
Mar 1, 2023 03:08 AM
ColonelSanders85
Dec 9, 2020 09:44 AM
Fisqual
Sep 22, 2015 05:51 AM
rshissler
Mar 24, 2015 10:46 PM
John_Keats
10
Jan 15, 2004 05:35 AM
