problem with tailights need help!
Old Sep 23, 2006 | 11:48 PM
darkshadowtc's Avatar
Default problem with tailights need help!
try to install these tail lights but when i do the fuses for my breaklights and other guages related to that fuse blow. ive replaced the fuse but it will everytime i install again, does anyone know how to fix this problem? need help badly.
http://cgi.ebay.com/ebaymotors/04-06...34923044QQrdZ1
only thing i could think of is that i need a stronger fuse or the lights are defective. any ideas?
Old Sep 23, 2006 | 11:59 PM
firesquare's Avatar
dont replace the fuse with a higher amp one. you can do damage to a lot of things or even catch the car on fire!! check the taillight wiring amd see if any of the wires are scraping the body of the car, causing a short. or email the seller see f their is a warranty/exchnge program they offer. some E-bay stores are good about things like that.
Good luck and those tails would look great with your color. i should know ;-) we have the same color car :-P
Old Sep 24, 2006 | 01:12 AM
captainlaziness's Avatar
*holds breath*
I was considering a version of those...but if I'm gonna have problems like that.....
Are you using the bulbs that came with the car or the taillights?
Old Sep 24, 2006 | 02:53 AM
eLpReSiDeNtE's Avatar
tC squad
the more i read the more i realize that yeah those taillites and those projector headlamps are nice looking but they are just a pain.....i much rather pass and wait till toyota themselves come out wit some projectors to get them.......i dont feel like going thru the headech or damaging my car
Old Sep 24, 2006 | 05:54 AM
gjpjr84's Avatar
well when hell freezess over, Toyota/Scion progect manager guy MIGHT get a note telling them to THINK about MAYBE doing just that, while he is having a drink with Hitler and Jesus Christ.
but really it sounds like your car is just rejecting your taste... j/k!
Old Sep 24, 2006 | 06:24 AM
tikbhoy's Avatar
there was a thread with info on how the receptacle of the plug on the lights are switched.
Old Sep 24, 2006 | 06:29 AM
tikbhoy's Avatar
did the search for u
https://www.scionlife.com/forums/vie...asc&highlight=
READ page 5
Old Sep 24, 2006 | 03:47 PM
the bulb is not the problem, there is a harness that goes from leds to the cars wiring some how the l.e.ds are to strong and sorts out the fuse.
Old Sep 24, 2006 | 04:27 PM
gjpjr84's Avatar
it would take a LOT more LEDs to be in that light for it to draw more power to blow the fuse.
Old Sep 24, 2006 | 05:38 PM
do you think about 20 small LEDs would be enough to blow them?
Old Sep 24, 2006 | 05:43 PM
gjpjr84's Avatar
no, im not an expert, but LEDs are extremely low power.
I have had 10 LEDs with a 2 amp fuse and never had any problems with it blowing, regular bulbs use a lot more.
you're connecting it wrong or grounding out somewhere.
Old Sep 24, 2006 | 06:02 PM
i think it maybe grounding out but dont know how to fix it or even know if iot can be fixed. my next bet is to find a tuner shop or electrical store and see what they can do, thanks for input anyway.
Old Sep 24, 2006 | 06:09 PM
gjpjr84's Avatar
i would first check the wiring that you have been messing with. make sure there are no breaks in it.
Old Sep 24, 2006 | 06:14 PM
SCIONtific_tC's Avatar
the problem is really that the harness is wired wrong. i got the same lights and it works fine after switching
Old Sep 24, 2006 | 08:37 PM
did you switch the wires or did you just get a whole new replacement?
Old Sep 24, 2006 | 09:03 PM
just pop the metal part out with a screw driver and switch them
Old Sep 25, 2006 | 12:20 AM
magyver's Avatar
wait, so try this.. if its the 7443 bulb, then you should be able to leave that out and plug in the tail and have the tail/brake/backup should work fine... if your having a problem w/ that aftermarket led bulb, then just put in an amber bulb to see.. as regular halogen's not care about polarity... but this is all hearesay as you have never once said that you put in led turnsignal bulbs.. so, not sure why the whole switching wires thing came into play...?!?!?
no, the led's arent drawing too much... to be honest, that should be a common sense concept by now.. as led's have been out for far too long for someone to think like that... w/ that said, a stock halogen bulb 194 draws 250ma.. that current draw in led's would be = to 7 crap quality led's that are prolly in those cheap tails... there are 20 per side, drawing a max of 3/4 of an amp.. which is gonna be 60+% lower than factory halogen bulb current draw...
so do what i say, put in stock bulbs in the area's that require bulbs.. and plug it in, if it dosent work w/ stock and still blows the fuse, then yes the actual harness is messed, ya need to sifer that.. but if you dont have led swap-outs, then you shouldnt have a problem... if halogen (regular glass bulbs) work, then yes, rewire your 7443 led bulb..
ScionXa06
May 18, 2015 10:05 PM
minter66
Dec 15, 2014 01:45 PM
dzcustom
9
Jun 25, 2004 01:51 AM
GruntStyle
Jan 18, 2004 06:09 PM
G-Force
9
Dec 12, 2003 12:36 AM
