Can someone confirm this wiring diagram for the emanage?
Old Sep 29, 2006 | 03:51 AM
unvdistc's Avatar
Default Can someone confirm this wiring diagram for the emanage?
Hey guys I had some issues with the wiring tonight and before re-doing it I would like someone to confirm this setup. I emailed Kenny at ZPI but wanted to see if someone could help me tonight.
The following is the way I think it should be setup. If you have changes or I made a mistake please let me know.
WIRING
GRAY - TH
WHITE - AR (IN)
GREEN - AR (OUT)
BROWN - I
BLACK - E
RED - +B
INJECTOR HARNESS
PRUPLE/RED - #4
YELLOW/RED - #3
ORANGE/RED - #2
BLUE/RED - #1
BLACK/RED - E
IGNITION
BLUE/WHITE - T1 (IN) - BLUE/BLACK - T1 (OUT)
ORANGE/WHITE- T3 (IN) -ORANGE/BLACK - T3 (OUT)
YELLOW/WHITE - T4 (IN) - YELLOW/BLACK - T4 (OUT)
PURPLE/WHITE - T2 (IN) -PURPLE/BLACK - T2 (OUT)
NOT USED!
#E Kn A W G Ne SPD
Old Oct 15, 2006 | 06:56 PM
MA_70's Avatar
I dont mean to be a dick or anything, and i know alot of companys have put lots of time and money into researching how to wire these things correctly but i just dont understand why this information cant be made public for people who would like to save some money and do it themselves.
Old Oct 15, 2006 | 08:35 PM
zer0's Avatar
Its available on the greddy website. Use pg2 and 3 of this .pdf.
http://www.greddy.com/img/PHP/products/pdf/838.pdf
Old Oct 15, 2006 | 08:45 PM
zer0's Avatar
Ill have to check for ignition harness.
Old Oct 16, 2006 | 12:07 AM
unvdistc's Avatar
this diagram was confirmed... the only thing that was wrong was #E is used for the injector harness ground. i have a complete diagram that I made and confirmed if anyone wants it PM me and I can email it to you.
Old Oct 16, 2006 | 01:53 AM
zer0's Avatar
Post the pic up on here if you have it. Or PM it to me.
Old Oct 16, 2006 | 02:06 PM
unvdistc's Avatar
Old Oct 18, 2006 | 12:54 AM
MA_70's Avatar
Originally Posted by unvdistc
Ah, see i missed that. Cause i was lookin and i couldnt find an ignition diagram and i was like wtf, but that helps alot. Thanks
Old Oct 18, 2006 | 01:07 AM
ERIC-TC's Avatar
Wow! Where did you find that pic with the pin-out info underneath? Would of saved me some time. The pic makes it look easy -but it's a pain in the **** to install...there is not much space to work with with a soldering iron and such. I'm going to install the ignition timing harness this weekend and it's going to be fun i bet!
Old Oct 18, 2006 | 04:57 AM
unvdistc's Avatar
i made it myself
Old Dec 15, 2006 | 06:35 PM
calvinwch's Avatar
i made it myself
any one of you have idleing problem? or anything need to change after you install emanage?
i got the blue emange, first was the problem for your throttle position which got fix buy your wiring diag. But after that, my car has idle problem. It just don't idle right rpm up and down than shut off engine.
I was wonder anything else need to do on it, or just need more tuned?
Old Dec 15, 2006 | 09:23 PM
unvdistc's Avatar
i made it myself
Are you running the emanage tool? so you can create your own maps? I can send you my map that i'm using. If not, probably the tune.
SuperXero
Scion tC 1G ICE & Interior
Feb 23, 2020 08:17 AM
streetracerr
Jul 11, 2015 09:52 PM
stillcole
Scion tC 2G ICE & Interior
Apr 6, 2015 03:42 PM
GetSlideways
Scion xD Drivetrain & Power
Mar 16, 2015 11:30 PM
