Front Seat Release Problem
Old Sep 30, 2006 | 03:56 PM
zm_br's Avatar
Default Front Seat Release Problem
I'm just seeing if any of you guys have this problem also. Whenever someone sits in my backseat, I have no problem with the seat release lever to slide either front seat forward. But, when I push the back of the seat to its original position, it catches and acts like it doesn't want to go.
I almost feel like I could break whatever is causing the problem if I pushed quick enough. Any of you guys have this also, or do your seats lock into position smoothly? I'm going to mention it the next time I have my car in, since it's not that big of a deal. I could post a video to illustrate what I mean.
Thanks
Old Sep 30, 2006 | 04:01 PM
azepolyn's Avatar
the driver's side should slide back into its original position, the passenger side does "lock" into place, and will need to be e-adjusted into position using the lower slide bar and tilt lever. Is that whats going on?
Old Sep 30, 2006 | 07:58 PM
imsonofagun's Avatar
I've noticed that it's a lot easier if you slide the seat until it stops before raising the seat back when you're trying to use the driver seat memory.
Old Sep 30, 2006 | 08:59 PM
DivisionbyZero's Avatar
If you keep the seat angled forward, and slide it back till it hits its 'memorized' location, and then recline (for lack of a better term) or 'return to the upright and locked position' you should avoid the catching and allow the seat position to remain 'memorized'
Old Oct 1, 2006 | 09:53 PM
zm_br's Avatar
Let me rephrase. Only the driver's side does the catching. It catches when the seat back is trying to lock back into its memory position.
This video shows what I'm talking about. 400kb
http://www.zmbr.com/images/mov03216.mpg
Old Oct 4, 2006 | 04:31 PM
zm_br's Avatar
ttt
Old Oct 4, 2006 | 08:22 PM
The dealer is -----> Thattta way.
There is no way thats normal behavior.
Old Oct 5, 2006 | 01:39 PM
zm_br's Avatar
ROFL THANKS. my map fell out the window.
seriously, i was just seeing if anyone else had similar situation.
eddienj
Scion tC 1G ICE & Interior
Jan 27, 2015 03:53 PM
carid
Jan 22, 2015 12:49 PM
torranosaurus
Jan 3, 2015 03:06 PM
moontom
Dec 15, 2014 04:14 PM
Docsnuff
15
Sep 2, 2007 03:25 AM
