Injectors
Old Oct 5, 2006 | 06:04 AM
fairladyz541's Avatar
Team Sushi
Default Injectors
I was woundering if anyone has a DIY for injectors. I am trying to see how hard they are to install or anything else I should know. Also, would I be able to use my SAFC2 to tune the injectors or will it not work. I am just trying to get this whole injector thing down since its so confusing. So, any information will help out a lot. What companies are good and what should I get. I am going to be using them for a turbo set-up.......Thanks
Old Oct 5, 2006 | 06:42 AM
WeDriveScions's Avatar
You need a Emanage with injector harness to tune them sufficiently... the S-AFCII is still way the underdog to the emanage and unichip setups (Mine is for nifty looks).. the install of the 550cc PNP ones from ZPI is cake... pull out, unclip, push in, clip... and done.
Old Oct 5, 2006 | 02:44 PM
Duy's Avatar
Duy
KAD
dont mean to thread jack but can u install bigger injectors without tuning em?
Old Oct 5, 2006 | 03:46 PM
3min3m2's Avatar
it would run rich.....unles you can match your boost with the injector size on the stock ECU...
good luck with that
Old Oct 5, 2006 | 04:30 PM
Duy's Avatar
Duy
KAD
nvm then lol i was just curious , im planning on boosting soon , and was researching and stuff.. someone told me 750cc injectors...is that overkill for someone aimin for 270 running 8.5 lbs daily?
Old Oct 5, 2006 | 04:36 PM
3min3m2's Avatar
yeah...550 is the biggest i tihnk they have for the tc(??)
but u need some sort of engine management either way...with the timing and fuel both need adjustments
glad your researching before starting.....i'm still learning too
Old Oct 5, 2006 | 05:00 PM
Duy's Avatar
Duy
KAD
yeah i know didnt want to just slap it on lol and blow ish up.. SAFC alone is not good enough for a turbo setup from what i understand so a piggy back is needed like an Emanage..there are places to buy those without the kit right? ive found them but only like in the Turbonetics Kit and the ZPI kit.
Old Oct 5, 2006 | 06:04 PM
Team Sushi
You know whats funny the two turbo kits that produced the most HP at the wheels both use the SAFC2.....
I am looking for a DIY for the injectors still......
Old Oct 5, 2006 | 07:03 PM
Schuller's Avatar
Look for the tC Turbonetics kit install instructions on the website. It’s a easy install. The injectors are held in place by the fuel rail. The fuel rail is held down with 2 bolts. Once you remove the rail the injectors pull right out then you can unclip them. Now you put the stock o ring on the new injectors and pop them in and reassemble the fuel rail. Now you can cut the old injectors clips off and solder the new clips on and snap them onto the new injectors. These are the 660 injectors that come with the Turbonetics kit. The second pic show the new clips attached to the wire harness.
Old Jan 18, 2007 | 07:43 PM
LIVETOROLL's Avatar
IF YOUR ONLY GOING TO BE RUNNING 7PSI AND HAVE ABOUT 250WHP DO YOU NEED TO RUN BIGGER INJECTORS OR WILL THE STOCK ONES WORK??
Old Jan 18, 2007 | 10:33 PM
2fast4you's Avatar
Team ScionTific
I would think you would want to run between 440cc and 550cc at that PSI... someone please correct me if I'm wrong.
Old Jan 19, 2007 | 04:15 AM
soros151's Avatar
There are indeed 750cc from RC for the tC, but of course, u will need a clip harness for those. :D
Old Oct 27, 2007 | 08:59 AM
olaHalo's Avatar
yo i know this thread is way old, but im putting my injectors on tomorrow and will be tuning my car on sunday.
anyone got a DIY for RC injectors? im trying to figure it out.
it doesnt look too hard but thanks if anyone has any tips
Old Oct 27, 2007 | 11:44 AM
soros151's Avatar
Don't crimp the connections, SOLDER THEM! If not, the car will hesitate.
Old Oct 28, 2007 | 12:32 AM
olaHalo's Avatar
thanks soros. i probably wouldve crimped them
Old Oct 28, 2007 | 02:28 AM
soros151's Avatar
Yep, that's what most of the people do.
SloTC1
Aug 16, 2018 02:45 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
k1114
Mar 6, 2015 03:43 PM
