Newbi here - Flame suit on
Old Oct 16, 2006 | 05:13 PM
Hacktc's Avatar
Default Newbi here - Flame suit on
Hello All,
I convinced my partner to by the 05 TC. I thought the ride was great and had major bang for buck.
Drove the TC yesterday. It has 11,000 miles on it. Its got two nasty issues and my partner wants to kill me for the push to buy it. I drive an 07 GTI, but love the TC for the price. Please help.
1) TC gets pulled from side to side over any road imperfection at low speeds, real tugging from side to side over rounded dips and bumps. At 80 on the highway its stable and smooth - any thoughts.
2) Feathering the pedal north of 1500 on the tach and less than 3000 brings on major hessitation feel. "drivetrain lag? .
Please help so I stay the consumate Ride purchase advisor !!!
Old Oct 16, 2006 | 05:16 PM
AgentRice's Avatar
welcome
the lag.. might be a tranny issue that u should have checked out
the pulling from side to side sounds like alignment or tires.. so check those
Old Oct 16, 2006 | 05:51 PM
brian's Avatar
EDIT: ignore my comment, i read your post wrong
Old Oct 16, 2006 | 05:52 PM
2fast4you's Avatar
Team ScionTific
Have you run a Carfax? It sounds like that tC has had some issues.
Old Oct 16, 2006 | 06:34 PM
Hacktc's Avatar
Hey, thanks for the quick replys.
The TC was purchased new and these issues have just developed over time. Suppose the first place I should check is Tires and Alignment. The wandering is def a possible alignment issue.
thanks again.
Old Oct 16, 2006 | 06:48 PM
web's Avatar
web
Car and Driver did the road test when the tC first came out and stated that depending on what suspension upgrades you have and types of rubber they come with, side to side motion on highways with ruts was common. The lower and grippier the tire, the more this was noticeable.
The "lag" in rpm pick up is due to the Drive by wire setup. The ECU is controlling the gas pedal, unlike older cars and simply other cars with cable driven throttle bodies. The lag can be deminished with light weight crank pulley and light weight flywheel, but it will not be taken away. Just something to deal with.
Old Oct 16, 2006 | 07:45 PM
Somnambulated's Avatar
Sounds like an alignment issue, if it's just becoming a problem now. If you hit a rut or are driving across a slope, the wheel may pull a little. If the car veers one direction for no apparent reason, it's probably alignment.
Stiffer shocks, too, seem to take some of that 'dude where's my steering wheel' effect away.
Old Oct 16, 2006 | 07:47 PM
web's Avatar
web
^^Agreed
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
sccarally
Regional - Lonestar
Aug 21, 2015 02:58 AM
Subaru86
Jul 28, 2015 03:05 PM
sciongirl13
Jul 22, 2015 02:28 AM
Ianno
Jul 7, 2015 04:35 PM
