215/40/18 or 225/40/18's???
Old Oct 25, 2006 | 12:57 AM
oneil261's Avatar
Default 215/40/18 or 225/40/18's???
so i just purchased some new wheels and tires but he said i can still change the size of the tire so wat should i go with 225/40/18 nitto neo gen or the 215/40/18 on my trd drop??
Old Oct 25, 2006 | 12:58 AM
Neothin's Avatar
get the 225's, they fit fine.
Old Oct 25, 2006 | 01:01 AM
oneil261's Avatar
why not the 215's
Old Oct 25, 2006 | 01:06 AM
Neothin's Avatar
if it fits, a wider contact patch is better.
Old Oct 25, 2006 | 01:09 AM
oneil261's Avatar
well do u think my drop is good or should i drop it down lower??
Old Oct 25, 2006 | 01:13 AM
Neothin's Avatar
what's the size/offset of the wheel they'll be mounted on?
I personally run a 225/40/18 on 18x7.5 enkei RP02's w/ a +48mm offset and tein stech springs with no problems.
Old Oct 25, 2006 | 01:15 AM
oneil261's Avatar
18x7.5 offset=45
Old Oct 25, 2006 | 01:18 AM
Neothin's Avatar
you can run my springs just fine w/ a 225/40 on that size wheel.
i like the *slammed* look, but the trd drop isnt going to look bad.
Old Oct 25, 2006 | 01:21 AM
Nick06tC's Avatar
deffinetly 225
Old Oct 25, 2006 | 01:30 AM
TimmyT's Avatar
Scion Society
how do they fit in your wheel well with a 45 mm offset?
Old Oct 25, 2006 | 01:31 AM
Neothin's Avatar
45mm is the same offset as stock
a larger postiive number offset actually sinks the wheels into the wheel wells towards the center of the car. a smaller number is what makes the wheels stick out of the wheel well
Old Oct 25, 2006 | 01:33 AM
TimmyT's Avatar
Scion Society
I know 45 mm is the same as stock, but he has a wider rim.
Old Oct 25, 2006 | 01:38 AM
Neothin's Avatar
1/2" isn't that much a difference from stock.
Old Oct 25, 2006 | 01:41 AM
oneil261's Avatar
will the hotchkis lowering kit make the front stick up like the trd drop does i hate that so much it bothers me
Old Oct 25, 2006 | 01:43 AM
PunkInDrublic's Avatar
225/40/18 keeps you close to the stock diameter as well, that way you don't throw off your speedometer.
ploniaczysko
Scion tC 1G Wheel & Tire
Jan 28, 2015 02:15 PM
sky-on
Aug 15, 2006 08:57 AM
ihaveatc
21
May 15, 2006 07:49 PM
JStead
9
Jul 25, 2004 07:45 PM
