Tire fitment 225/40/18 ???
Old Oct 27, 2006 | 07:38 PM
kenr74's Avatar
Default Tire fitment 225/40/18 ???
I'm hoping for some good news here but from everything I have read I think I'm screwed.
I bought a set of tires/wheels on ebay and they were supposed to be 215/35/18(23.93"). What showed up was 225/40/18(25.08") which is over 1.25" bigger than stock. The seller pretty much said too bad and he isn't going to fix the problem so I need some advice.
I had planned on putting on the Tanabe springs with these tires but I don't think that will work. I'm guessing that I can run these at stock height but has anybody ran these with a lowered ride? I looked at the sticky and didn't see anything that helped.
Old Oct 28, 2006 | 06:14 AM
slowmo923's Avatar
I ran those with TRD springs. It works for me, but only 1 in drop
Old Oct 28, 2006 | 01:25 PM
kenr74's Avatar
Well, I fit them up last night and need spacers in the back but the fronts were ok. I don't have the new springs on though so I guess I'll try them and see what happens.
Old Oct 29, 2006 | 01:15 AM
YELOSUB's Avatar
Wagonistas
Definately go with TRD's or something close to that drop...You might get away with a 5mm spacer which is simple to install, or go with the 10mm shims spacers that go behind the hub...These take more work to install, but are still a piece of cake!
P.S. Sometimes you gotta hate ebay!
Old Oct 30, 2006 | 08:57 AM
hotbox05's Avatar
just a little bit gigantor .
more than an inch taller diameter
huge sidewall too. and the wider tires are more rolling resistance aka less mpg.
Old Oct 30, 2006 | 02:58 PM
kenr74's Avatar
Well, I can see there is no way these are going to work with the DF210 springs. Guess I'll put the drop on hold since I am stuck with the tires. I do 30k+ a year so I should burn through these tires pretty fast and then get the ones I actually wanted.
So..........anybody looking for some Tanabe DF210 springs. I haven't even opened the box yet.
Old Oct 30, 2006 | 05:41 PM
hotbox05's Avatar
sell the tires.
Old Oct 30, 2006 | 06:58 PM
balddave's Avatar
I've got some TRD springs if you want to work some sort of trade for the DF210's Let me know
Old Oct 31, 2006 | 02:51 PM
chipzxb's Avatar
I had the same setup for a while. The front rub on turns, the rear worked perfect with the 5mm shim, and the 40series fill the wheel well perfect with the df210. Just exchange the front for 215/35. Keep the df210's they are great.
Old Oct 31, 2006 | 07:40 PM
hotbox05's Avatar
the fact of needing a 5mm spaces could be way off. he may need a 20mil spacers or no spacers that depends upon wheel offset.
Old Oct 31, 2006 | 07:42 PM
kenr74's Avatar
Do you have some pictures with that set up? I think I can live with the tires on front. The rubbing isn't to bad. I have the OTG spacers on the way so once those are on I'll have to decide to drop it or not for now.
Old Oct 31, 2006 | 07:48 PM
kenr74's Avatar
Right. These wheels are a 40 offset so I need a decent spacer. I put some washers on just to see how things would look/fit and came up with about 6mm minimum. I went ahead and ordered the OTG spacers so I have a little extra room behind the wheel and should still have space near the fender.
Old Nov 1, 2006 | 02:14 PM
chipzxb's Avatar
Let me see if I can dig up a picture. My wheels are a 45mm offset and a 5mm worked great. I could have used a little more to flush it but I didn't.
Old Nov 1, 2006 | 04:59 PM
kenr74's Avatar
Pictures would be great. You don't have any rubbing on the inside by the frame? Once I get the spacers on I should have a better idea of how well it will work with a drop. I hate to put the drop on hold but after just buying the car and rims I'm broke so new tires are not an option for a while.
Old Nov 1, 2006 | 06:06 PM
chipzxb's Avatar
I did without the spacers. But after they went on no more problems.
scionlife
371
Jun 2, 2015 11:00 PM
r3aper503
May 15, 2015 06:31 PM
Deves
Feb 8, 2015 11:37 PM
ploniaczysko
Scion tC 1G Wheel & Tire
Jan 28, 2015 02:15 PM
rolex87
Nov 3, 2003 06:35 PM
