would this be a bad thin to do?
Old Oct 28, 2006 | 02:27 AM
fl1p_tc's Avatar
Default would this be a bad thin to do?
i like the trd drop but i want the front to be dropped more.... would you guys think it would be ok to just swap the fronts with h-techs and leave the rear with the trd ones..... or would the ride be not that great?
Old Oct 28, 2006 | 06:20 AM
sddykstr's Avatar
Probably not the best idea. Could be bad on your struts to have an uneven drop like that.
Old Oct 28, 2006 | 04:54 PM
im4degreesaboveu's Avatar
im not condoning this in anyway but your best bet to do this is on coilovers that way its a little easier to adjust but i wouldnt do it man
Old Oct 28, 2006 | 07:15 PM
engifineer's Avatar
Would probably handle like complete @$$
Old Oct 28, 2006 | 07:20 PM
Nick06tC's Avatar
I dont know personally. But different springs available for the tC have different drops from front to back so what would be the difference if you used trd rear, hotchkis front?
Most people would say, well there is different spring rates between the two, different ride heights. And that is true. BUT, people put adjustable coilovers on and then adjust dampening force, ride height, shock rates and there is no problem. When you corner balance a vehicle, all 4 corners will have different settings, heaights, and adjustments, and that is when you get THE BEST handling in a car.
So why would it be bad to have two different style springs?
Old Oct 28, 2006 | 08:32 PM
fl1p_tc's Avatar
thats what i was thinkin.. cause maybe some people might think hotchkis or h-tech are too for their likin and might consider trd or somethin and we could just swap out cause i have a shop where we can do it for free....but anyway thanks for the replies
Old Oct 28, 2006 | 08:48 PM
engifineer's Avatar
It wouldnt be bad if they were adjustable. If they arent, you are just rolling the dice as to whether they will balance well on the car together. When you run un-even drop, you are changing the weight distribution characteristics as well, so you really need a set that is built to work together or something adjustable so you can properly tune it.
Old Oct 28, 2006 | 08:52 PM
Nick06tC's Avatar
Doesnt EVERY company (for the tC) run an un even drop tho? (except trd) I havent heard anyone complain about the un even drops.
Just throwing thoughts out there. I dont know from personal experience. Just havent heard any issues with s techs for instance. (an un even drop)
Old Oct 28, 2006 | 08:57 PM
engifineer's Avatar
My point is not that an uneven drop is bad, it is that the set of 4 springs is designed for the uneven drop and the characteristics changed. If you go mix and match, they springs are not garaunteed to be optimized for each other.
Old Oct 29, 2006 | 02:56 AM
fl1p_tc's Avatar
every springs have different rate and height to them...both tein and hotckis have more of a drop on the front...both have different spring rates on them...most springs have a lower drop on the front too.. and havin the trd spring i know that they drop more than stated by trd... more like h-techs...people who have/had the trd kno what im talkin and just by seein pic too...but anyways..yea
BlingSlade
Oct 19, 2016 12:39 AM
a23r
Feb 1, 2016 04:05 AM
dougcbx
Oct 23, 2015 11:42 PM
mudguy
Oct 22, 2015 04:31 PM
BlingSlade
Sep 5, 2015 08:52 AM
