ATF Dipstick removal / replacement!
Old Dec 1, 2006 | 02:40 AM
mike6789k's Avatar
Default ATF Dipstick removal / replacement!
Hey,
As some of you already know, I am going to embark where no one has yet to go before, take a 2006 greddy kit, use a new maf pipe, and run that on my 2007 tc!
Now, the next problem I have to tackle is the ATF dipstick... how did you other auto guys move it / remove it? Because i'm assuming it gets in the way of the charge pipe...
Thanks!
Old Dec 1, 2006 | 03:58 AM
soros151's Avatar
Unbolt it.... and move it a little to the side.....ziptie it to another thing away from the manifold... no?
Old Dec 1, 2006 | 04:23 AM
mike6789k's Avatar
im sorry, where are the bolts? and near the top there is some rubber hose running to the metal =\
Old Dec 1, 2006 | 04:30 AM
soros151's Avatar
sorry, I thought u meant the Oil dipstick. WOW, the tranny fluid dipstick... hum... that's a though one. I don't have an auto, sorry.
Old Dec 1, 2006 | 02:03 PM
318_tC's Avatar
i got the dezod kit and i didnt have to move it anywhere =
Old Dec 1, 2006 | 02:19 PM
soros151's Avatar
are u 07?
Old Dec 1, 2006 | 02:25 PM
318_tC's Avatar
No, but im 99.9% sure there is no differnce in where the dipstick is.
Old Dec 1, 2006 | 02:31 PM
ERIC-TC's Avatar
It is a very tight fit -but it can be done. Anyone have pics of Greddy on A/T tC? That's what we need. I've been told the Greddy kit works on the A/T so it has been done before.
Old Dec 1, 2006 | 02:36 PM
soros151's Avatar
Okay
318_tC's Avatar
i thought that u had to make the kit fit cause if u ask greddy they say the kit wont fit.
Old Dec 1, 2006 | 04:07 PM
mike6789k's Avatar
haha, well greddy says the 05 kit wont fit the 06's... they arent very smart when it comes to specific tC info
so who here has greddy on ANY year auto? was the dipstick in the way?
Old Dec 1, 2006 | 08:16 PM
krdshrk's Avatar
Um. I'll find out next weekend. Maybe sooner if I can get ahold of Gizmo and get a pic of hers.
Old Dec 1, 2006 | 10:55 PM
DK01's Avatar
I have an 06 auto with the Greddy kit. All I did was unbolt the tranny dipstick and bent it little to the side so the piping wouldn't hit it directly. I have no problems with it.
Old Dec 2, 2006 | 02:30 AM
mike6789k's Avatar
which bolt?
thanks!
Old Dec 2, 2006 | 02:27 PM
soros151's Avatar
Is there a bolt maintaining the dipstick in its position? If so, that one. Look for it from top to bottom.
Old Dec 2, 2006 | 07:45 PM
mike6789k's Avatar
ok ill do that now, only problem is i cant find the bottom! haha
Old Dec 3, 2006 | 02:37 AM
soros151's Avatar
bottom of the stick.
Old Dec 3, 2006 | 04:13 PM
azuresky's Avatar
I had to trim off the top of mine to make it fit w/ my kit.
As in... remove the dipstick, use a dremmel to trim off part of the orangish handle, then everything was ok.
Old Dec 3, 2006 | 04:32 PM
ERIC-TC's Avatar
There is also a little trick that you can do to get more space.
Remove the top coolant hose and install it backwards. This will give you more space to route the intercooler piping. between the intake pipe and the side of the battery.
Old Dec 4, 2006 | 06:09 AM
DK01's Avatar
There is a bolt on the tranny bend of the dip stick tube . Unbolt it and you will be able to bend of the whole dipstick to the right. So later, if you plan to go back to stock, you can bend it back and bolt it right back up. I didn't have to bend the dip stick too much to mess up anything. If I remember right, there is only one bolt that you will see and you can't really miss it.
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
torranosaurus
Jan 28, 2015 04:53 AM
kleecker
Jan 9, 2015 02:26 PM
Opr8r
20
Jan 1, 2004 05:52 AM
