stock speakers
Old Dec 5, 2006 | 04:38 AM
VIVALI's Avatar
Default stock speakers
hey anyone no the factory size speakers installed in the scion tc?
2 ?x? tweeters?
2 ?x? on the door ?
and 2 ?x? to the rear?
help me out here people
thanks in advance
Old Dec 5, 2006 | 04:52 AM
rocketgyrl's Avatar
They're 6.5"s in the doors and rear. The tweeters are a joke, and should you purchase aftermarket speakers, I suggest disconnecting them. I wouldn't try to squeeze aftermarket tweeters in their location either...
My advice is to buy 4 of the same "good" coaxial speakers and mount them to 3/4" MDF baffles secured to the metal. Don't forget the Dynamat! :D
Old Dec 5, 2006 | 05:25 AM
VIVALI's Avatar
lol...you would laugh if i told you , you lost me here? ? ?
could you break it down for the less technical please
thanks for the reply though
Old Dec 5, 2006 | 05:27 AM
haiduy's Avatar
haha i bought infinity reference speakers for the front 6.5 6012IR and my sister i think is gettin me the MMC6500 for the rears with tweeters i hope thats a good combo and maybe an amp for everything and i have the bazooka sub as well in the back
Old Dec 5, 2006 | 06:49 AM
rocketgyrl's Avatar
I'll do my best to simplify it for you...
Here's what your rear speaker mounting locations look like (ignore what I'm holding - and visualize your factory rear speakers in the tear-drop shaped hole):
A "baffle" is a board that you mount the speaker to. This is important because speakers vibrate to cause sound, and physics (more specifically Newton's 1st law - an object at rest....) plays a key role here. A baffle will help "mass load" the speaker, and the result is better sound/performance. Dynamat is the same idea - mass loading/damping the area around the speaker to lower resonance and quiet the car's rattles - allowing for a more efficient audio system (less energy required to fight/overcome road noise). Here's a picture of speaker mounted to a baffle:
Old Dec 6, 2006 | 03:48 AM
Tcguy85's Avatar
leave them stock, mess with the settings on the deck till your happy and add a good sub and amp. thats what i did and i absolutly love it. i think ssp "feel" on the XA setting sounds good with the bass on +2 and treble on +3 or +4, and the fade +1 to the front. i have no distortion or popping or anything.... it sounds loud and clear, especially with my sub in the back. i do not plan to ever change out the stock speakers or the stock deck EVER in this car it sounds fine as it is and i want to keep mysteering wheel controls and ipod hookup.
Old Dec 6, 2006 | 05:10 AM
rocketgyrl's Avatar
The tC's stock system is one of the best STOCK systems available- but for those that want more, it's certainly available and there's LOTS of room to grow. There's plenty of after market head units that offer iPod control (Premier 880, Alpine 9865, 9857, etc.), and this January at CES will offer even more iPod friendly units.
The PAC SWIX is one way to continue to use the factory steering wheel controls, or for those that are more electronics friendly, it's fairly easy to work around them as it's just a voltage divider (multiplexed) setup. If you search on here, it's already been discussed.
tcguy85 - I'm glad you're happy with your setup, but let's not be so quick to suggest to others who asked for a better system that the stock tC system is as good as it gets...
Old Dec 6, 2006 | 05:11 AM
haiduy's Avatar
are our speakers 2 channel single channel or 3 or 4 channels?
haiduy's Avatar
im about to install the infinity speakers 6012IR to the front but is it better in the rear?
Old Dec 6, 2006 | 05:27 AM
rocketgyrl's Avatar
In my car, there are no rear speakers for this reason: when you go to a concert, all the live music is coming from in front of you. Ideally, all the sound produced should sound like it is at about eye level over the dash, and it should image (create a distinct left, center, right....just like the band on stage. That image becomes distorted the more sources of sound you have.
My advice would be to install the infinity speakers up front, and disconnect the back speakers. Although you might carry around some passengers back there from time to time, for your daily driving (presuming only 1 - 2 people usually) it will sound a lot better.
Trying to help you out with the channel question: it's a 4 channel set up. The Pioneer head unit is 4 channel out, basically one channel for each corner of the car (Front L, Front R, Rear L, Rear R...the tweeters DO NOT have their own channel).
Old Dec 6, 2006 | 05:30 AM
haiduy's Avatar
oh i see koolio i just got a 4 channel amp
zuck5150
Apr 9, 2015 10:21 PM
SuBSiN
Mar 13, 2015 04:02 AM
Inazuma
Dec 3, 2003 10:06 PM
1sikxb
Nov 10, 2003 04:01 PM
vpkb
Oct 7, 2003 01:35 AM
