Emanage PnP Harness + Auto - Help!
Old Dec 12, 2006 | 12:47 AM
krdshrk's Avatar
Default Emanage PnP Harness + Auto - Help!
Is anyone using the Emanage Ultimate PnP harness with an Auto tC ('06)? I got mine installed and tuned, but now I'm getting a CEL for Speed Sensor A, and the speedometer does not work. Was I given the wrong PnP harness, or is there some wiring that needs to be changed? Help!
Old Dec 12, 2006 | 04:45 AM
OuterHeaven's Avatar
Does your speedo work again when you remove the emanage??
Old Dec 12, 2006 | 01:48 PM
318_tC's Avatar
I didnt have the problem and im a 06 auto. you got something wrong some where.
Old Dec 12, 2006 | 02:50 PM
krdshrk's Avatar
Ok after my Phone/IM convos today with several people, including Paul @ Dezod, we're thinking it could be a bad emanage unit. I'm getting a OBDII scantool to check on the system now, and then i'll clear the problems and try to run a little bit on the stock ECU to see if the problems persist.
Old Dec 12, 2006 | 03:15 PM
ERIC-TC's Avatar
Is e-manage getting the RPM signal? If it is then maybe the wire that goes back to the ECU is not connected. I mean if emanange was unable to read RPM's then it would be impossible to tune your car as all maps have RPM's on the horizontal scale...
Old Dec 12, 2006 | 03:19 PM
krdshrk's Avatar
RPM's are reading yes. Speedometer (speed sensor A) no.
Old Dec 12, 2006 | 03:55 PM
ERIC-TC's Avatar
Emanage ultimate has a way of by-passing the max vehicle speed by intercepting the speedo signal. Look there first.
Old Dec 13, 2006 | 09:38 PM
krdshrk's Avatar
Ok it wasn't ANY of these... I took it to a stealership - apparently they had to fix a lot of wiring.
Old Dec 13, 2006 | 10:00 PM
paul_dezod's Avatar
Scionetics
KAD
PM sent Nick.
Old Dec 13, 2006 | 10:17 PM
krdshrk's Avatar
Thanks for the followup, Paul.
The problem I was running into was wiring on the car itself... Apparently something went bad.
ABS + the Shifter interlock wiring had to be repaired.
Old Dec 13, 2006 | 10:26 PM
zer0's Avatar
Why did it need repaired? What damaged them?
Old Dec 13, 2006 | 10:46 PM
krdshrk's Avatar
Don't know what caused it....
Old Dec 14, 2006 | 04:05 AM
ERIC-TC's Avatar
What did the dealership do when they popped the hood and saw the big bad turbo? Did they move you to the naughty list?
I know when I take my car to the dealership to change the oil the kids at the oil change station where like "Dude come over here -you gotta to see this TURBO tC and it's A/T too!
Old Dec 14, 2006 | 04:10 AM
krdshrk's Avatar
Yep naughty list.
They charged me for the wiring repair... which makes no sense to me because the turbo install didn't go anywhere near it...
I'm gonna talk to Scion corporate about it.
Old Dec 14, 2006 | 04:14 AM
ERIC-TC's Avatar
You know if the seat brakes they will blame it on the turbo for producing excess G's
Welcome to life -with no warranty...
BlackKnight
Sep 15, 2015 06:42 AM
SportyPT03
Aug 24, 2015 04:14 PM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
mav261
Feb 11, 2015 02:43 AM
